@old_iron avatar
Mp3 500 ( Darkside)
@old_iron avatar
Mp3 500 ( Darkside)
I found ( I think ) the problem.. tilt lock pressure switch shorting out..
jpg
522kb
jpg
522kb
jpg
522kb
jpg
522kb
@storm avatar
MP3 400
@storm avatar
MP3 400
Water in the switches seem to be a common problem. I've started covering all of the switches in dialectic grease which solves that problem.
@bubbajon avatar
RIP: MP3 500 - Brutto Moto
@bubbajon avatar
Yep - I posted a thread years ago on treating all the switches and connectors. There's also a product you can get called "Liquid Tape" that works well for the back of the connectors. Most connectors Piaggio went cheap and they are NOT sealed against the elements.
@alexb avatar
2008 MP3-500
@alexb avatar
2008 MP3-500
+10... that's one of the first things I do with any new-to-me vehical, absolutely essential for riding in the rain, or long-term ownership.
@old_iron avatar
Mp3 500 ( Darkside)
@old_iron avatar
Mp3 500 ( Darkside)
Well I didn't know if it was water or brake fluid or a plain'o connector failure .. But I called Scooter West.. They want $114.00 for a new one.. so I put everything back together and I added the dieletric grease. I'm sure am happy to find the problem.. and to get it straighten out..
@bubbajon avatar
@bubbajon avatar
You really do need to read this if you don't want it to happen again...
Weatherproofing connectors
@wick avatar
2009 Piaggio MP3 500
@wick avatar
Do you have a link to that thread BubbaJon? I am interested in heading this problem off at the pass. I put a lot of miles on my scooters each year. I would just as soon address this issue now before it strands me somewhere.
@old_iron avatar
Mp3 500 ( Darkside)
@old_iron avatar
Mp3 500 ( Darkside)
. Thank You BubbaJon for the link. It will be a great help.. Funny thing we spend alot of money on buying these wild machines and they were put together by clowns Clown emoticon
Vespa PX 200
Vespa PX 200
⚠️ Last edited by peartree on UTC; edited 1 time
@web-tech avatar
@web-tech avatar
He posted the link, it's in blue
@wick avatar
@wick avatar
Sorry...I had the thread open and got distracted doing something else in the middle of writing my question. He posted the link during that time. I just hit submit and walked away. Sure made me look dumb though
Thanks for the link BubbaJon. I will get crackin' on this after I get back from Amerivespa.
@alexb avatar
2008 MP3-500
@alexb avatar
2008 MP3-500
Dumb question, but why not simply Bypass the switch, thereby eliminating it from the system?
Seems this would solve the nusance of "5 alarms at startup" while still retaining normal tilt-lock operation, assuming you maintain proper bleeding of the system over time... Worst case is that your tilt-system is mushy from being non-bleed.
Thoughts?
@bubbajon avatar
@bubbajon avatar
Thoughts?
Safety. Not a good idea IMHO.
Piaggio mp3 500
Piaggio mp3 500
Re: Zombie Scoot problem found
If there is liquid in that pressure switch can it be cleaned out and if so how?
@old_iron avatar
Mp3 500 ( Darkside)
@old_iron avatar
Mp3 500 ( Darkside)
Phillip the tilt lock low pressure switch need's to be replaced.. The switch developed very small crack's on the inside letting fluid in from pressure .. I try'ed cleaning it out and throwing in some dielectric grease but it didn't hold up and it pop the fuse again. Did you take the panel's off to take a look to see if you have the same problem ?
Piaggio mp3 500
Piaggio mp3 500
I was not sure I had to take them off. Will do if that's is the only way. Did not want to!!
@old_iron avatar
Mp3 500 ( Darkside)
@old_iron avatar
Mp3 500 ( Darkside)
Don't worry it's a easy job.. But keep track of all the screw's. You'll do a good job.. Popcorn emoticon
Piaggio mp3 500
Piaggio mp3 500
I had them off about two years ago. Start at the bottom?
@old_iron avatar
Mp3 500 ( Darkside)
@old_iron avatar
Mp3 500 ( Darkside)
Yes Sir start at the bottom.. Just head's up the " tilt lock pressure switch is a white connector with a purple collar on it with a blue plug going into it "..
[ Time: 0.0238s ][ Queries: 6 (0.0111s) ][ live ][ 318 ][ ThingOne ]
