Posts: 4170 Location: Huntingdon, Cambridgeshire |
The fan on my GTV keeps coming on. I've checked the water and its ok, it's like when a car is stuck in traffic and starts to overheat.
Re: Fan kicking in all the time
Pepy27 wrote: The fan on my GTV keeps coming on. I've checked the water and its ok, it's like when a car is stuck in traffic and starts to overheat. |
Buddy Pamplona 50cc, Vespa GTV 250ie
Posts: 1519 Location: Saint Louis |
Where are you? In the summer, in stop and go traffic mine comes on too, (I have a 2009 GTVie). I think that is normal. Unless there are indicators that oh are overheating I don't think you need to worry. I think your fan is doing its job. When I first got mine I sort of panicked too. But unless there is something else going on I think you are fine.
Sir Frets-A-Lot
Posts: 11197 Location: Bee eff eee. |
Coolant and water is fine.
No leaks, levels don't change. Cheeky thinks a poor connection to the sensor. Not sure how I can tell if the water pump is pumping? |
I've had it come on in hot weather after a bit of a ride but the temp is high at the moment and it starts almost as soon as I start riding.
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
Posts: 6064 Location: Northants UK |
Pepy27 wrote: Not sure how I can tell if the water pump is pumping?
Fingers Crossed
I've replaced the Thermostat (item three), bled the system, removed and cleaned the water sensor (twice, once with a cloth and once with wire wool), i'm now going to replace the water sensor (item eight).
GTS 250ie "gone" & others vintage
Posts: 356 Location: Paris, France |
Disconnected the battery for about a week, reconnected today and ran her at idle for about 10 minutes. Took her for a brief run and voila no fan kicking in. After the Ace meet and the lumpy ride, poor starting etc. she seems like new again. 8)
