hi i wonder if anyone has any suggestions i have a preleader et4 125 it vibrates alot on idle and has become really jerky at low revs when on full throttle its great but obviously cant go around at full speed thanks
I sincerely apologize. I know you must be frustrated that your Vespa isn't running right. I just saw the thread et4 jerky and I couldn't resist. (Like beef jerky... Jack Links is a brand)
Sorry again
Since it runs well on full throttle, the easiest place to start would be opening the variator up to clean out any dust and grime and replace the rollers if any even slightly out of round. (You didn't mention how many miles on the scoot or if it gas been sitting for extended time, but most people seem to change out their rollers and belt at same service time). I would also run some Seafoam (a carb cleaner / fuel stabilizer here in the States) through the gas incase there is any gum or clog in low speed jets.
Beyond basic troubleshooting and maintanace, I am not much help. Good luck - doesn't sound too serious.
