@cj_scoot avatar
2007 GTS 250 ie
@cj_scoot avatar
2007 GTS 250 ie
changed belt OEM, and switched to DR Pullys...
drove 150 miles ish, when decelerating heard a whining noise.
discovered oil leaking into case.
found/repaired leak at gasket adjusted dr ps
drove 100 miles ish
more oil leaking into case
same leak... found what looks like where the belt was rubbing to find this.....
removed dr ps, reinstalled orig
repaired leak.
did the dr pullys do this?
0:7 And counting
0:7 And counting
What variator? Stock or something else?
The belt rubbing the cases and ripping out the oil pan gasket is not unheard of (it happened to me, more than once) but generally only with an aftermarket variator.
0:7 And counting
0:7 And counting
Oh, and it's more likely to happen on a fresh belt as well, since it is nice and wide when new and can climb up the pulleys better.
0:7 And counting
0:7 And counting
One final question: did you have the thin 1mm washer installed between the inner bushing and the outer variator, as is proper? Without that 1mm washer, you're almost guaranteed to have this problem if you ride WFO.
See: I know what the washer is for! A WARNING to J Costa Owners!
@cj_scoot avatar
2007 GTS 250 ie
@cj_scoot avatar
2007 GTS 250 ie
Stock variator..
When I removed it there was no 1mm washer there..but there seems to be a indent where one belongs...?!?
GTS 250ie "gone" & others vintage
Even with washer i had the issue on my gts 250. Went back to stock roller.
0:7 And counting
0:7 And counting
CJ Scoot wrote:
Stock variator..
That would definitely do it. Without the 1mm washer in that indent, the outer pulley half will be closer to the inner pulley half, and at WFO that will cause the belt to climb high enough in the pulleys to start eating the engine cases.
And that's exactly what happened to me in the thread I linked to above.
@midnight_rider avatar
09 GTS (sold) 2014 NC700XD
My washer was stuck to the outer variator half when I took eveything apart the first time. When I went looking for it on reassembly I found it on the floor. It must have fallen out of the indent when I moved the variator half around on the floor...
GTS 300ie
GTS 300ie
Happened to me last week.. after fitting new belt.. i have malossi variator..
i wasn't sure what caused it, thanks guys for the explaination.
@vnb avatar
1964 VNB, GTS300, Harley Davidson FLD Switchback
@vnb avatar
I can't believe Piaggio doesn't make the case slightly larger to eliminate this from happening. Why take the chance on a tiny washer solving the problem? I've heard of the same thing happening with stock parts and everything installed correctly. The oil pan gasket sticking out just a tad much can cause and oily mess when it gets nicked.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
What is the easiest gasket fix?
0:7 And counting
0:7 And counting
This problem is very rare when the stock variator is correctly assembled with the washer in place. And realistically, in the worst case scenario, the penalty for not correctly assembling the transmission is fairly minor: one gasket and one belt.
@modnrod avatar
Lambretta child
@modnrod avatar
Lambretta child
I had 2mm of gasket sitting proud of the case lines when I put my DP variator on for testing, so to give a bit more leeway I took it back to the surface level with a sharp knife. Now, no gasket for the belt to grab.
If you mean though how to repair a broken gasket? Besides replacement?
Threebond (used correctly).
@cj_scoot avatar
2007 GTS 250 ie
@cj_scoot avatar
2007 GTS 250 ie
Thank for the info
Adding the washer tonight-
Is 2 mm better?
0:7 And counting
0:7 And counting
CJ Scoot wrote:
Thank for the info
Is 2 mm better?
No. You'll lower your top speed.
@cj_scoot avatar
2007 GTS 250 ie
@cj_scoot avatar
2007 GTS 250 ie
Is this a washer you can get anywhere or scooterwest order only. I need to do this job tomorrow
Can't wait till wed
0:7 And counting
0:7 And counting
Can't wait till wed
It's fairly special. It's thinner than most washers and has a hole sized to fit over the crank. You won't find it at the hardware store.
07 LX50
07 LX50
I read here that some one found these washers by accident .Was it fender washers?I don't remember .He had his mic and found the size he was looking for and bought extra's...Ill post if I find it.
@cj_scoot avatar
2007 GTS 250 ie
@cj_scoot avatar
2007 GTS 250 ie
just went back to stock rollers for the trip down, getting the proper part @ Amerivespa.
Hope to see you all there!
[ Time: 0.0336s ][ Queries: 5 (0.0069s) ][ Debug on ][ 313 ][ Thing One ]
