1. Spare tire placement options
2. Attach bracket Mock-up and proof of concept
3. Bracket fabrication
4. Wheel installation
5. Horn relocation. Guess where the wheel will be mounted?
6. Review and observations
wheel placement option 1, in wheel well...loose quite abit of storage and foot placement
wheel placement option 2, on rear rack, loose aft storage
wheel placement option 3, upright on rear rack, not ascetically pleasing, would need to fabricate a bracket to mount
wheel placement option 4, on scooter side---like a pannier this would occupy the space of a pannier as pannier space is more valuable and would make the bike asymmetric.
wheel placement option 5, front faring mount. This location provides a few challenges. The challenges include:
1. clearance with front wheel faring
2. wheel attachment to scooter
3. Horn relocation
4. loss of front load carrying capability
5. headlight visability
headlight is partially blocked, I'll need to "rake" the wheel as to limit headlight beam blockage
will mount on OEM front rack
disassemble rack, won't need these parts
re-install rack
quick wheel fit check, wheel contacts post
trim post, need to tuck wheel as close as possible to scooter
make bracket from aluminum rectangle bar stock
fit about here
drill oversized hole matching the front bracket
trim attach flanges
light deburr all mounting holes
rough machined bracket, repeat process
break edges with deburr tool
add loop adhesive velcro to the bracket to front rack contact/touch points as to spare the finish of the front rack
mount check
wheel base-plate out of wood first, then metal
trim with band saw
wheel check
attach base-mount to bracket interface to front rack
attach to scooter
mount wheel to baseplate
scooter fit check
no front fender contact
still some headlight blockage, need to rake the wheel and will try another mount approach
vespa GTS front wheel hub ($30 from e-bay)
opposite side of hub, these hole attach to your front brake disc
need to trim off small tabs to make a flush surface, easy-peasy as hub is aluminum
trimmed hub
trim down the large disc to accept the hub
remove front decorative trim as the tire will tuck to a lower position, plug holes with fastener
aluminum sheet stock, 6061-T4 .125 inch gage
outline transfer from wood to metal
blend corners at 1.5 inch radii
cut on band saw
deburr
mount on bracket
mount assembly on rack
prime (2x coats) + paint (2x coats) the wheel hub
mount assembly on scooter
front view, notice the assembly blocks the horn and running light
countersink fasteners
attach hub with course thread M6 fastener, use blue loctite paste
fit check, no tire contact with scooter or bracket, only hub
front fender check, no issues
view from top
remove stebel horn from cavity. Stable horn install can be found here:
Installation of the Stebel horn on a Vespa GTS step-by-step
will mount the horn here
need additional hose and elbow hose couplers
bond straight coupler into stebel nozzle
mount with fastener here
straight connecter bonded in horn hole
thread nozzle hole thru bracket
horn as attached
horn/hose backside view
assembly on scooter
assembly front view
need to thread horn hose thru plastic trim, no real other option
connect horn hose with hose elbow connector, easy to disconnect if assembly needs to be removed
horn mounted
wheel clearance to top of front fender
front 1/4 view, closer tucked wheel, no headlight blockage
outside front view
side view
front 1/4 view
horn mount side view
horn front view
headlight view from ground
Mod review and observations:
1. Additional piece of mind if need to conduct fix a flat where plug is insufficient
2. Certainly will mount for any long distance riding
3. No additional noise at hi-way speeds
4. Stebel horn is perceived to be ~30% louder, from re-location
5. assembly weight ~ 20 lbs, this will have benefit in cross wind conditions
6. some increase in front impact crash worthiness
7. benefit to other vespa riders if touring with GTS scooters
Enjoy!
Keithm
