Hello All,
I've got a very strange, and aggravating problem. Today I went to start my MP3 500 and the starter wouldn't even engage. I know the brake lever switches are working just fine. I could see my brake flashers firing, so that's not the issue. I had to try pushing the starter button at least a dozen times before the motor finally started turning the engine. When the engine started it ran for about 1.5 seconds and then died. I tried the starter again and once more the starter motor wouldn't turn. Another dozen attempts later I was able to get the engine to start and this time it ran for two seconds before dying. After five minutes or so I managed to get the engine going and ride for about 400 feet before the engine cut out, and this was not at idle. About ten minutes later I got the bike started again and revved the snot out of the engine to keep it from dying. I managed to get the bike two miles down the road to get it home. Along the way it would hesitate every now and then as if it was missing a power cycle every few rotations. When I reached my driveway it died once again just in front of my garage. I tried restarting it one more time and the motor once again would not engage. A half dozen more attempts and the engine was running at idle with seemingly not problems.
Now I'm at a loss for what single issue could be causing the starter to not engage, the engine to die after starting, and the engine to misfire randomly. Any ideas are greatly appreciated as I would have to ride quite a distance to get the scoot looked at, and I don't want to risk breaking down halfway there.
