http://www.buzzfeed.com/daves4/jokes-only-nerds-will-understand
I loved number 17.
Posts: 4755 Location: Hertford, North Carolina |
2012 GTV 300 & LXV 150
Posts: 3487 Location: Pacific Northwest |
That's good stuff.
If I ever get a ticket for speeding, I am considering taking exception to a phrase that is often misunderstood and misused, and argue my case in court. Here is how the argument may go, if I was, perhaps, over the speed limit but trying to slow down at the time I was caught: Sharp: The officer told me I was traveling at a high rate of speed. But my rate of speed was zero. Judge: That's impossible. You were moving, correct? Sharp: Yes I was moving, at a rate of speed of zero. No, wait, actually I was traveling at a negative rate of speed. Judge: You were backing up? Sharp: No, I was slowing down. Judge: Backwards? Sharp: Forwards. Slowing down whilst traveling forward. Judge: I should hold you in contempt of my court; One, for giving this crazy story about going backwards, and Two, for using the word "whilst"... |
Not wanting to be too captious, I think that 'rate of speed' is a velocity*. 'Rate of change of speed' is an acceleration.
(*Velocity is speed and direction). |
Raputtak wrote: Not wanting to be too captious, I think that 'rate of speed' is a velocity*. 'Rate of change of speed' is an acceleration. (*Velocity is speed and direction). Acceleration = (rate of speed) =(distance/time/time) So when people say "rate of speed" they really mean rate, or speed, but not both. When holding a constant rate, even 85 MPH, your speed is 85 MPH, but your "rate of speed" (change in speed, or acceleration) is indeed zero. |
Excalibur Silver 2007 GTS 250: "Merlin"
Posts: 100 Location: New Brunswick, Canada |
I learn something new everyday, and at this rate of learning I may well end up knowing less than I did...
sharpcolorado wrote: Raputtak wrote: Not wanting to be too captious, I think that 'rate of speed' is a velocity*. 'Rate of change of speed' is an acceleration. (*Velocity is speed and direction). Acceleration = (rate of speed) =(distance/time/time) So when people say "rate of speed" they really mean rate, or speed, but not both. When holding a constant rate, even 85 MPH, your speed is 85 MPH, but your "rate of speed" (change in speed, or acceleration) is indeed zero. :nerd: |
skymed wrote: I learn something new everyday, and at this rate of learning I may well end up knowing less than I did... |
Posts: 5262 Location: Tempe, AZ |
Raputtak wrote: skymed wrote: I learn something new everyday, and at this rate of learning I may well end up knowing less than I did... |
Posts: 3711 Location: Babcock Ranch, Florida |
An old nerd joke, probably has been on here before:
There are 10 kinds of people, those who understand binary and those who don't. (Kind of like the OCT/DEC joke above.) |
Tor2ga wrote: An old nerd joke, probably has been on here before: There are 10 kinds of people, those who understand binary and those who don't. (Kind of like the OCT/DEC joke above.) There are 2 kinds of people: Those who think there are only two kinds of people, and everybody else. |
Posts: 2467 Location: Menifee, CA. (Land of the Dirt People) |
saggezza di scala
Posts: 7068 Location: Israel |
saggezza di scala
Just FYI, my daily commute is 49,947.1148 Smoots, each way.
If you know what a Smoot is, chances are you are already a nerd. If not, you can find out more here: http://en.wikipedia.org/wiki/Smoot BTW, along with most other units of measure and currency conversions, entering "X miles in Smoots" (with X = to the distance you want to convert), into Google will provide the answer for you. No joke! |
BV 500 Bagger, Atlantic 500, Stella 150 4T, Mojito Custom 150, Baron 150.
Posts: 534 Location: Roseville, and Yosemite NP CA |
Trepp, The more I read from you, the smarter I get. 10,591.5224 smoots for my freeway commute, 14752.4776 if I use surface streets.
saggezza di scala
saggezza di scala
Rail 50 wrote: Trepp, The more I read from you, the smarter I get. 10,591.5224 smoots for my freeway commute, 14752.4776 if I use surface streets. I'm a rich repository of unrelated/uncataloged trivia, minutiae, and random 'facts' (with said 'facts' being open to debate). But that doesn't make me smart any more than one would call the sack holding the groceries 'nutritious'. |
Treppenwitz wrote: Rail 50 wrote: Trepp, The more I read from you, the smarter I get. 10,591.5224 smoots for my freeway commute, 14752.4776 if I use surface streets. I'm a rich repository of unrelated/uncataloged trivia, minutiae, and random 'facts' (with said 'facts' being open to debate). But that doesn't make me smart any more than one would call the sack holding the groceries 'nutritious'. |
Treppenwitz wrote: Just FYI, my daily commute is 49,947.1148 Smoots, each way. If you know what a Smoot is, chances are you are already a nerd. If not, you can find out more here: http://en.wikipedia.org/wiki/Smoot BTW, along with most other units of measure and currency conversions, entering "X miles in Smoots" (with X = to the distance you want to convert), into Google will provide the answer for you. No joke! |
saggezza di scala
saggezza di scala
dmpawley wrote: Treppenwitz wrote: Just FYI, my daily commute is 49,947.1148 Smoots, each way. If you know what a Smoot is, chances are you are already a nerd. If not, you can find out more here: http://en.wikipedia.org/wiki/Smoot BTW, along with most other units of measure and currency conversions, entering "X miles in Smoots" (with X = to the distance you want to convert), into Google will provide the answer for you. No joke! But if I had to guess, I'd have to say the transparent pipe probably has something to do with MITHenge (the twice yearly event when the sun sets in alignment with the Infinite Corridor and shines along its entire length). |
Treppenwitz wrote: No idea, having never attended MIT. I did visit there quite frequently on business since my company was collaborating with several of the on-campus start-ups. That's how I absorbed some of the MIT lore, such as the 'Smoot' unit of measure. But if I had to guess, I'd have to say the transparent pipe probably has something to do with MITHenge (the twice yearly event when the sun sets in alignment with the Infinite Corridor and shines along its entire length). |
