I got a question about the front end of my Vespa GTS (2006 model)
I changed the wheel bearings on it because there was a little play on the old ones.
They are non adjustable so the play that's on them is the way it is.
With the new bearings in place the play still feels the same.
With the front wheel off the ground I can "move" the wheel a little bit (like you would do to feel to adjust old tapered ones).
Is that "normal"..??
Also I got a question about changing out the top and bottom steering bearings.
There is already a topic about that: Replacing top and bottom steering bearings
But I just wanted to know how to make the room in the brake hose to get the fork all the way out..??
All this comes form the feeling there is something wrong with the front end of my Vespa.
It improved allot with the malossi shock, but still it feels "loose" or how do I say it..
I used to have an old Piaggio Thyphoon (50cc model) and I was able and felt confident enough to trow it full wack in to almost every corner.
I know that has a normal upside down fork, not a single swing arm, but I also used to have a Peugeot speedfight (don't think they got into the states) that had a single swing arm in the front.
But that felt like on rails, and I never had an unsafe feeling like I get from my GTS now.
I had the dealer drive with it but they don't feel anything wrong with it, but I think that says more about them then about my Vespa.
[edit]
Extra info:
When I let go of the handle bars the GTS swings to the right, and also when I pull on the front brakes really hard it starts to "shake" or "jump" if you get my drift.
