@sportique avatar
Motovespa 150s
@sportique avatar
Motovespa 150s
2003 px125 with a polini 180 kit and scorpion exhaust. This is the set up someone I know is running they currently have a 20/20 si carb and are looking to try and find a bit more speed. The advice they were given was to use a 30mm dellorto a rubber mounting and to lose the air filter.
What would this achieve realistically and is it ok to run without a filter? Any advice appreciated.
@magg avatar
Vespa GL Touring 180, Vespa GL 225, Vespa PX 200 Sahara Edition
@magg avatar
I would think a 30 mm phbh is way too big for that setup. Unless of course you've done some fancy porting, adding a reed valve setup etc.
If that's a bolt on polini 177 without any extra porting and just the regular rotary valve, you'll probably be fine with just an si24/24.
A phbh 26 or 28mm might add a little extra at the top, but you'll loose quite a bit of low end power.
@rgconner avatar
GTS250
@rgconner avatar
GTS250
No air filter means that your rotary valve won't last long.
Anything getting in there is going to "sandpaper" it down until it fails.
A porting and crank job would be the next logical step.
[ Time: 0.0087s ][ Queries: 3 (0.0022s) ][ live ][ 339 ][ ThingOne ]
