Can you recommend a 2 stroke oil you have been using for your vespa to mix it with gas?
Is there a brand to prefer or is there a brand to stay away from?
Thanks so much!
Is there a brand to prefer or is there a brand to stay away from? Thanks so much! |
RIP
This one may get a lot of varied answers... so I'll just give my short 2c.
Stay away from über cheap chainsaw / yard tools stuff. I always use Motul 710 and swear by it... it's more expensive than some but worth it in my O. No splooge and never a problem! %2 every time! (premix) And here are some other suggestions.......... |
Vader19 wrote: This one may get a lot of varied answers... so I'll just give my short 2c. Stay away from über cheap chainsaw / yard tools stuff. I always use Motul 710 and swear by it... it's more expensive than some but worth it in my O. No splooge and never a problem! %2 every time! (premix) And here are some other suggestions.......... |
Oil is like underwear, either you like tighty-whities, silk panther print banana boats, or boxer briefs. How do you like your nuts tucked?
Seriously, this topic has been covered before. Amsoil Dominator, Motul 510 or 710 are some of the best. Personally I only use 710, but would use Amsoil Dominator if I could not get 710 or if my drug habit got out of control. 710 =
RIP
Vader19 wrote: What's with the cardboard tubes on the floor.. clean that shit up!!!! |
Dugan wrote: Vader19 wrote: What's with the cardboard tubes on the floor.. clean that shit up!!!! |
Speed_Kills wrote: Dugan wrote: Vader19 wrote: What's with the cardboard tubes on the floor.. clean that shit up!!!! |
Speed_Kills wrote: Dugan wrote: Vader19 wrote: What's with the cardboard tubes on the floor.. clean that shit up!!!! Or also could be chew marks while sitting on the john. That's what I do with my chair in the bathroom. |
Posts: 6897 Location: GT, Texas |
You didn't mention any particulars about your Scooter (year/make/model). Most Vespas made after 1980 and the Lambretta 75SL ' Cometa' have automatic oil metering devices with a separate oil tank. I recommend Motul 510 or 710. Consult this page for your year/make/model Vespa and pre-mix instructions. Do not take our word for it. Do your research.
http://books.google.com/books?id=YwMDEUn1V3gC&pg=PA155&lpg=PA155&dq=1964+Vespa+GL+premix&source=bl&ots=F-0lCXfDse&sig=-RiILWpkEbKy187mTFe81FTz9y0&hl=en&sa=X&ei=AMHaUfO-Fenw0QHcjIGQBw&ved=0CC0Q6AEwAA#v=onepage&q=1964%20Vespa%20GL%20premix&f=false Note: Go all the way to the bottom of the page for pre-mix instructions page 154. Common examples of pre-mix differences. Also remember modern Syn Oil is much better than what was produced in 1960's... Just Saying. Most Vintage Vespa Models (Non-Piston Ported) 2% Piston Ported 3%-5% 62-64 GS Model 5% 57-60 125 Model 5% 64-68 180 SS Model 5% |
astromags wrote: Yes, what scooter did you end up getting, miami? |
dewkeating wrote: You didn't mention any particulars about your Scooter (year/make/model). Most Vespas made after 1980 and the Lambretta 75SL ' Cometa' have automatic oil metering devices with a separate oil tank. I recommend Motul 510 or 710. Consult this page for your year/make/model Vespa and pre-mix instructions. Do not take our word for it. Do your research. http://books.google.com/books?id=YwMDEUn1V3gC&pg=PA155&lpg=PA155&dq=1964+Vespa+GL+premix&source=bl&ots=F-0lCXfDse&sig=-RiILWpkEbKy187mTFe81FTz9y0&hl=en&sa=X&ei=AMHaUfO-Fenw0QHcjIGQBw&ved=0CC0Q6AEwAA#v=onepage&q=1964%20Vespa%20GL%20premix&f=false Note: Go all the way to the bottom of the page for pre-mix instructions page 154. Common examples of pre-mix differences. Also remember modern Syn Oil is much better than what was produced in 1960's... Just Saying. Most Vintage Vespa Models (Non-Piston Ported) 2% Piston Ported 3%-5% 62-64 GS Model 5% 57-60 125 Model 5% 64-68 180 SS Model 5% 1963 VBB with LML Stella 150 cc 5 port engine with a sito plus high performance sport exhaust. |
1974 Primavera 125
Posts: 152 Location: Naples Florida |
miamiscooter wrote: astromags wrote: Yes, what scooter did you end up getting, miami? |
This is not my information. It was taken from another site...
Depends on what you mean by a "Stella" engine. The engine as installed in the Stella is oil injected, and does not need premix (it still consumes oil, as all two strokes do, but it has a seperate oil reservoir and does the mixing itself). However LML produces a 5 port Stella style engine designed to be used as a replacement engine for classic Vespas. This one DOES require premix, as would most classic Vespas. Example here: http://www.scooterworks.com/Engine_150cc_-_5_port_NON-INJ_P3905C466.cfm I would guess that they probably put the pre-mix version of the engine in, rather than take an engine out of a Stella and then make a premix reservoir. |
dewkeating wrote: This is not my information. It was taken from another site... Depends on what you mean by a "Stella" engine. The engine as installed in the Stella is oil injected, and does not need premix (it still consumes oil, as all two strokes do, but it has a seperate oil reservoir and does the mixing itself). However LML produces a 5 port Stella style engine designed to be used as a replacement engine for classic Vespas. This one DOES require premix, as would most classic Vespas. Example here: http://www.scooterworks.com/Engine_150cc_-_5_port_NON-INJ_P3905C466.cfm I would guess that they probably put the pre-mix version of the engine in, rather than take an engine out of a Stella and then make a premix reservoir. |
I am an Si-7 guy, on the recommendation of HRA.
He likes the 710 too, but I think the SI-7 burns cleaner on my bike. |
I only use Amsoil in my gas mixture and belray in my gearbox but \I use a high grade gear oil because of my clutch plates
As mentioned a "Stella" engine would be fuel injected and therefore premix would not be needed.
Is there an oil site glass on the frame below the fuel tap and choke levers? |
Quote: Mon Jul 08, 2013 10:42 am As mentioned a "Stella" engine would be fuel injected and therefore premix would not be needed. Is there an oil site glass on the frame below the fuel tap and choke lever |
RIP
WP2 wrote: Anyone give the Motul 800 a try? 710 FTW! |
Plus one on Dominator.
Also, I can understand the empty toilet paper roll in the bathroom. But WTF is an empty paper towel roll doing there? Pper towels=no bueno on plumbing! |
RIP
rufio wrote: Plus one on Dominator. Also, I can understand the empty toilet paper roll in the bathroom. But WTF is an empty paper towel roll doing there? Pper towels=no bueno on plumbing! |
Vader19 wrote: rufio wrote: Plus one on Dominator. Also, I can understand the empty toilet paper roll in the bathroom. But WTF is an empty paper towel roll doing there? Pper towels=no bueno on plumbing! |
RIP
Ok... all you guys seem to be dancing around it... so I'll just say it!
I think those shorts make his buns look wonderful! oh... Motul 710 %2 |
Sorry, the good deals are done. Too many people took advantage of the good prices and we almost sold out. Edited for this reason.
⚠️ Last edited by Scooter West on UTC; edited 1 time
Motorsport Scooters wrote: We've always loved Motul 710 and still swear by it. We did buy out Piaggio's remaining stock of full synthetic Selenia 2T oil and it's fantastic. Especially at $9.97 per quart. If you buy 5 you get the 6th free. If you buy 10, you get the 11th and 12th free. It's a fantastic deal on fantastic oil while it's still around. The only problem some people have had with it is that it's clear, so it's a little more difficult to see in the sight glass than the other colored oils. http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/Official-Vespa-2-Stroke-100--Synthetic-Oil-by-Selenia/8662 http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/SIX-PACK-Vespa-2-Stroke-Oil-100--Synthetic/8663 http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/12-BOTTLES-Vespa-2-Stroke-Oil-100--Synthetic/8664 If you get your order up over $100, you can even get up to $20 worth of free shipping. |
Vader19 wrote: WP2 wrote: Anyone give the Motul 800 a try? 710 FTW! |
ScooterRaton wrote: I got a bottle of that with Chef Aaron's GS...being clear weirded me out! figure I will blend a little Bel-Ray in to make it light blue and easier to see. |
rgconner wrote: ScooterRaton wrote: I got a bottle of that with Chef Aaron's GS...being clear weirded me out! figure I will blend a little Bel-Ray in to make it light blue and easier to see. Also, I always ran Motul 800 on my high performance scooters that were not injected and loved it. My P-221 never seized once, and I attribute it to the 800 (and not running an engine cowl). The 800 is pre-mix only, though. |
Just wish I had thought of it while I was down for AmeriVespa... 15% extra off....
ah well. |
Motorsport Scooters wrote: The 800 is pre-mix only, though. |
