@craigtebeau avatar
'74 rally 200 x 2; '62 LI150
@craigtebeau avatar
I am converting my Rally system to 12v. At first I was going to simply take the battery out of the loop. Now I am wondering if I should keep a 12v battery in the loop to smooth out the lights.
any opinions on this option?
It seems to me that they must have kept a battery in these things for a reason over the years... am I correct or are these set-ups just better without the battery.
any input appreciated.
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
you got it right.
@nebulae avatar
Vespa Rally 210
@nebulae avatar
Vespa Rally 210
jamesjohn wrote:
you got it right.
Got what right?
Battery in?
Battery out?
Razz emoticon Razz emoticon
I did a 12v conversion.
New harness from Beedspeed, new rear brake switch & new light switch.
No battery - not needed.
What sort of Rally engine you got?
Ducati?
Femsa?
There may be other mods required if its a Femsa engine and you want to fit a P range flywheel & stator.
@craigtebeau avatar
@craigtebeau avatar
I got it right
Whatever I said, was right, I guess. Clown emoticon
Anyway. I have the Femsa Rally 200 1974 stock.
I have never had any problems with ignition.
going to 12 v for the lure of brighter lights.
Maybe I should just buy a new 6V regulator and new battery-I have tried that in the past... never that impressed. Constantly trickle-charging is annoying.
Would tend to lose charge over time, but mainly the 12 v halogens are brighter, with options such as additional lighting, louder horns etc. seems like a good conversion for all those reasons.
I like stock vespa appearance, but when it comes to bike's function, upgrades don't diminish.
I suppose the value of a P-200E stator would be some increased amperage (watts) available? or what ?
cheers
@jamesjohn avatar
@jamesjohn avatar
aww shit! drunk posting. sorry.
I meant you were right they kept batteries for a reason. to level out the lights brightness. and yes you could go with or without if you want.
ill try to be more thoughtful next time. good luck with yer build.
@vader19 avatar
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
@vader19 avatar
jamesjohn wrote:
ill try to be less drunk nest time. gool luck with yer buiuld.
fixed that!
@jamesjohn avatar
@jamesjohn avatar
lol
[ Time: 0.0095s ][ Queries: 3 (0.0029s) ][ live ][ 339 ][ ThingOne ]
