Howdy,
So my SIP Road v1.0 had a good 20,000km's on it, and one de-coking, and that honeycomb stuff was starting to fall out, so I just got my hands on one of these SIP Road 2.0 exhausts. It's acquired two exhaust spring hooks, which is a good feature, methinks, because my previous SIP Road had been held on by, variously, shims made from beer cans, coke cans, tomato paste tins, grease cans, and even the 0.15mm shims that SIP sell. Even then it was hard going to get the thing to seat properly right up at the base of the exhaust stub.
I understand the bit about putting the 2-holed steel extender bit on the cylinder shroud screw, and attaching one spring to that, and for the other spring I'm supposed to drill a little hole at the bottom end of the outermost cooling fin and hook it in there.
I see, though, that for the forward spring to connect to the cooling fin, that spring's gotta be massively stretched out. Adding to my concern is that this is a Polini 210 nikasil barrel. The thing just feels so light and so brittle. Also, I seem to remember reading elsewhere about people having trouble attaching springs to aluminum cylinders. Breaking fins and so on. And now I can't find that information for some reason.
Does anybody have any experience with this? Also, would it be feasible to just hook up the one spring to the cylinder shroud screw and leave it at that? Or would that exert any damaging lateral force on the exhaust stub? (Sorry if that sounded paranoid. Just trying to be thorough here.)
