Sorry to be posting something so specific, but I figure that maybe any answers to this question could be general enough to be of use to others. Here goes!
So I blew a hole in my piston and decided to replace the crank so long as I was in there, seeing as the big bearing in the old crank was visibly full of aluminum shards and presumably some molten aluminum as well. (Both cranks are the exact same model, W5 60mm's, for regular rotary valve engines.)
Anyway, I installed the new crank, tightened the clutch on, and found that the inside edge of the crank web was scraping against the crankcase. Flummoxed, I started taking measurements of the new crank vs. the old, and found that the shoulder on the clutch side of the shaft measured 7.6mm. Meanwhile, on the old crank (but same model), the shoulder was 7.8mm. 2/10ths of a millimetre ain't much, I suppose, but in this case it's enough to get things scraping.
So my question is, is there any reliable solution here? Some sort of shim I can install? Or will I have to write this one off and just go back to my old crank, and pray that the big bearing holds out?
Cheers
Sean
