Lx150 ie
Lx150 ie
Have an LX150 and the tire pressure gauges I have wont fit so I can get to the rear tire. Any special gauge everyone uses. Also set front at 24 dealer had it 28. Decal calls for 23.2 front and rear 29 and rider 41, I am 200 lbs so should I go with 41. Also should I add some pressure for longer tire life.
The digital Slime ones fit, as will any 'pencil' type gauge.
I'd set the rear to ~34 psi if I was 200lb - 41 is pretty near the max!
Over-high tyre pressure doesn't necessarily lead to longer tyre life, as you'd wear out the centre quicker. It could also introduce grip problems depending on conditions.
@rangeraj avatar
2011 300GTV
@rangeraj avatar
2011 300GTV
I picked up a digital gauge from Napa Auto Parts.
Been working like a dream for over 2 years now.
@yucca avatar
2008 GTS 250
@yucca avatar
2008 GTS 250
Slime digi works great. 10 bucks or so at the auto parts store.
http://www.slime.com/shop/sport-digital-tire-gauge-20017/
@dave92029 avatar
2013 GTS 300ie Super - Dragon Red
@dave92029 avatar
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
I thought I read that those extensions would hit something when the wheel revolved.
Hence the advice above never to leave them attached after checking/filling...
Popcorn emoticon
@nightwing avatar
Contributor
Contributor
@nightwing avatar
Popcorn emoticon
Perchance you would point me to the above referenced info.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
Common sense.
NightWing wrote:
Popcorn emoticon
https://modernvespa.com/forum/post1661104#1661104
[ Time: 0.0102s ][ Queries: 3 (0.0016s) ][ live ][ 339 ][ ThingOne ]
