This is the second time in 2 months that the same cylinder stud has stripped its threads under the head nut. WTF is going on?
Some facts and observations...
This is a PX150 ('05) and it normally uses 7mm x 140mm studs. I torque the nuts carefully in an x-pattern to 11 lb-ft using a calibrated wrench.
This started happening after the head was replaced by HRA with a non-Piaggio one that I'm thinking might be a bit thicker since the nuts seem to torque down closer to the end of the threads than they used to. During rebuild I did measure each stud for length after install and this particular one did seat about 1 thread deeper into the case than the others, consequently it's about 1 thread shorter than the others. That said, all nuts do completely clear the threads when torqued, but they are close to the end.
Just guessing, but should I be using the longer version of studs? Would that help? I'm not sure why this keeps happening on this particular one. Anyone have any suggestions?
