Please help how to replace brake pads on vespa gts 250..just confused that whether I need to flush brake fluid to remove brake caliper ..oh and I will start with the front brakes first and then proceed to rear if successful. Please advise.. thanks
You do not need to flush or bleed the fluid to change the pads. However, if the fluid is more than a few years old, or discoloured rather than clear, it's best to replace it.
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
