@muzzywolfy avatar
piaggio vespa et2 50cc
@muzzywolfy avatar
hi , can anyone help me out here , I've got a vespa et2 50cc (2001) and the petrol seems to be going down faster than it normally does ? I've looked around engine and can see no visable signs of leaks any ideas or solutions please
Welcome to MV mate.
I see you're from England. That means someone is probably stealing your petrol. Find them and get them deported to Australia.
@muzzywolfy avatar
@muzzywolfy avatar
Laughing emoticon that had crossed my mind ha ha & thanks for the welcome
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
vest
hes obviously been to newcastle
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
Are you sure your fuel gauge is working properly?
Mines way off
@rangeraj avatar
2011 300GTV
@rangeraj avatar
2011 300GTV
When my scooter goes through fuel at alarming rates, I usually find it is caused by long weekend rides.
@muzzywolfy avatar
@muzzywolfy avatar
Not been on any long rides , used for work only ,short trips.
Aloha and welcome to the forum fro Hawaii. I'd also agree it might be being nicked, Can you find a safe place (friend, family) to keep it for a few days and see if the problem goes away, Gas stealing is the in thing to do over there. Easy rule out then we can look for other things if i still continues.. good luck
@raiderfn31 avatar
PGO Buddy 150 "St Tropez" imported by Genuine scooter co.
@raiderfn31 avatar
ROFL emoticon Clap emoticon
@greg531 avatar
@greg531 avatar
I heard of the nicking of fuel, but usually they cut the gas line.....
You might have a guy that is only taking a couple of quarts at a time, reattaching the line....
I would check your lines for cracks, and run new ones to the carb, if they have not been replaced yet....You have 12 year old rubber in them if original....
et2 fuel mileage
Mine uses more juice than I thought it would, but the throttle is pinned to max most of the time. I'm getting anywhere from 45 to 55 mpg. It's a blast to ride though.
[ Time: 0.0099s ][ Queries: 3 (0.0016s) ][ live ][ 339 ][ ThingOne ]
