Troubleshooting what appears to be a fuel starvation issue at high RPMs with my smallframe.
Before I tackle more difficult issues like pulling the tap (already cleaned carb and am probably over-jetted, as is) was wondering if someone could point me in the right direction on fuel line length.
I had it longer a while back, but it kept getting kinked between the frame and the throttle arm. Shortened it up, but now I'm wondering if it is too short (just long enough to get from tap to banjo going over top of the carb without kinking).
I know too long is such a thing, but is too short a problem too? Reading conflicting length suggestions and figured someone here might have a better idea.
Also, should I be concerned about gravity with the line running over as opposed to under the carb, or is the vaccum enough?
What about using black rubber fuel hose as opposed to the clear line?
Thanks.
