say if you have a parked LX150, -- what is the average wind speed tipping point (in mph or kph)?
Resident Gentleman
Posts: 5045 Location: Brady, TX |
Posts: 1811 Location: Los Angeles, CA |
Posts: 8758 Location: Annapolis, MD, USA |
crock wrote: For all motorcycles and scooters, the tipping point on level ground is about 70 mph. The tipping point of a PTW is a function of many variables... including -- but not limited to -- the horizontal distance from the plane of the center of gravity to the downwind leg of the stand, the height of the center of gravity, the bike's weight, it's cross-sectional area and aerodynamic drag coefficient from the side, the air temperature (which significantly affects density and therefore the amount of force the wind can exert), and the angle at which the wind is striking the vehicle. Considering that these variables range wildly from bike to bike and situation to situation, it is impossible to make such a generalization. Even among Vespas, the stability with respect to wind tipping will vary considerably... the profiles and weights of an LX150 and an old P-series Vespa are similar, but the wide stance of the P's stand and its lower center of gravity will make it much more stable than an LX on its relatively narrow footing. If you are simply parroting something you read or heard somewhere, it might be wise to think it through before repeating it.
Positive
Is your bike parked out side?If you live where you can mount tie downs to the ground that will keep the bike up.
Posts: 7695 Location: Madison, Wisconsin |
Thunder Thief
Posts: 2360 Location: in the blue ridge mountains of Virginia... on the trail of the lonesome pine..." |
Thunder Thief
Silver Streak wrote: crock wrote: For all motorcycles and scooters, the tipping point on level ground is about 70 mph. The tipping point of a PTW is a function of many variables... including -- but not limited to -- the horizontal distance from the plane of the center of gravity to the downwind leg of the stand, the height of the center of gravity, the bike's weight, it's cross-sectional area and aerodynamic drag coefficient from the side, the air temperature (which significantly affects density and therefore the amount of force the wind can exert), and the angle at which the wind is striking the vehicle. Considering that these variables range wildly from bike to bike and situation to situation, it is impossible to make such a generalization. Even among Vespas, the stability with respect to wind tipping will vary considerably... the profiles and weights of an LX150 and an old P-series Vespa are similar, but the wide stance of the P's stand and its lower center of gravity will make it much more stable than an LX on its relatively narrow footing. If you are simply parroting something you read or heard somewhere, it might be wise to think it through before repeating it. |
froggieposition wrote: I am going to buy you a beer next time we hang out. 👍 |
Thunder Thief
Thunder Thief
Silver Streak wrote: froggieposition wrote: I am going to buy you a beer next time we hang out. 👍 |
