I can get you a close up if you like. It's been a while since I changed a tire. It's a 2 piece pipe & seems like I had to just loosen the big bolt that holds it on the pivot arm and the slotted tab comes off as you swing the muff away from the tire on the header pipe.
That picture works as I was wondering how it sits on the scoot. The stock one sits in front of the tire where this one seems to sit off to the side. Thanks V oodoo! Hope to see you soon!
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
