@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
The part labelled 1.. Is it a scoop? Not sure but I need one, anyone know where I can get hold of one?
Also 2.. I need one of the screws from here as ones missing
Any help would be great cheers
@ks7877 avatar
@ks7877 avatar
Vespa Motorsports / Scooterwest is a forum sponsor and they have every part under the sun (pretty much). But they're not local to you and shipping costs would probably be way too high.
Do you have a nearby wrecker you could call? or a reputable dealer? Even if they don't have the part, they may be able to steer you in the right direction. Good luck!
@fentonfred avatar
2009 Piaggio MP3 250
@fentonfred avatar
Re: I'm after a part.. Help
I have ordered parts from PSN Tuning and AJ Sutton in the UK, I was happy with both.
Scooterwest is excellent and very knowledgeable, but as the other poster said the shipping costs probably won't be cheap. Do you have access to a parts diagram for your model? If you can find the exact part number, that will probably help.
@vnb avatar
1964 VNB, GTS300, Harley Davidson FLD Switchback
@vnb avatar
You can pretty much use any screw.
@hairball avatar
2013 Vespa 300 SS
@hairball avatar
2013 Vespa 300 SS
+1
@xmanhoe avatar
@xmanhoe avatar
bout yee
the part labeled no 1 is a plastic cover , not expensive , look on e bay for one , the screw labeled no 2 holds it in place and the rear bit just clips in
@raputtak avatar
@raputtak avatar
Oops. I thought you were an out-of-work actor.
[ Time: 0.0152s ][ Queries: 4 (0.0077s) ][ live ][ 339 ][ ThingOne ]
