A month ago my husband took my BV 500 in for service at 9,900 miles for belts and rollers, figured I'd have the spark plug changed at the same time.
We took it in because not only was it time for regular service but because it was stalling occasionally at stop lights. On the way down from Breckenridge to Denver the scoot did run hot but the light did not come on. My husband did stop to let it cool off when the gauge showed it touching red.
The estimate we got said that there was a coolant leak and that the brakes needed replacing in addition to belt and rollers. I was supposed to pick it up on Friday with a bill of $512.
Today I get a call that says after they had reassembled it when they took it for a test ride they discovered a second coolant leak and it now needs a thermostat, flywheel cover ($240 for part), flywheel cover gasket, fork sleeve so now they want $1,300. Does this make sense?
Having been off work since my accident in April I really can't afford the repairs they are claiming as necessary now. Thoughts? Advice?
