I've done some research, registered with this site (thank you modernvespa.com!) looked over the Repair Manual PDF's, poured over pictures and acquired a workshop manual. I'm aware of the steering head "notch" issue and made a checklist of what I would want to look for during pre-inspection and after I got the bike home.
Seeing that I'm the adventure type with motorcycle-impulse-buying issues, I figured I would be bringing the bike home with me regardless. I have several motorcycles, but I recently purchased a scooter for my wife and now I have the bug to have one myself.
I drove out to Monroe, LA to look at the bike on Wednesday. It was dirty from sitting outside at a pickup truck wholesalers lot for 2-3 months. They replaced the battery during that time and it started right up.
I rode it for about seven miles total and it's an unusual motorcycle until you get a feel for it. I noticed the odd steering behaviors right away...
I was prepared for the steering issue and picked up on it right away as it was all over the road a low speed and I noticed something strange from the transmission too. I made the seller aware of the steering head issue and negotiated an already low price to an even lower price, and loaded the bike up and headed home.
From that first ride it was obvious, it has a VERY LOOSE front end, with quite a bit of play in the steering. You can see the lower steering-head bearing slop around when you move the handlebars. It doesn't seem to be the "notch" I keep reading about, but its all over the road at low speeds, almost as if the steering head nut and jam-nut have backed off, like it needs to be tightened back up in the steering head. You can easily see the slop at the lower head bearing, the bearing looks dry and the balls tap around when you move the handlebars.
On my way back home, I stopped by a Vespa dealer (very friendly and helpful), they felt if was in need of some adjustment, but said it could be wasted bearings too, they would not commit until they could get it torn apart, they figured 2.5 hours of labor, I'm fine with that. I'll make an appointment in the coming weeks.
The bike cleaned up very well, I mean its in fantastic shape with 7900 miles. The plastic doesn't have a scratch, the Maddstad windshield is absolutely flawless, it has a RAM mount neatly tucked in above the dash. It has the modernvespa highway pegs and a MMG (?) tailcase that I know nothing about, but it is in great shape and comes right off without unbolting anything. The tailcase mounts to a well-made (homemade) baseplate.
ALL the fluids look nearly new, everything is topped off, the brake fluid looks new and there is no scoring on the rotors.
The air filter was immaculate. It has a new Michelin City Grip rear tire, front tires are original and look a little thin.
I'm perplexed by the steering head issue. The bike seems well cared for, I'm getting quotes for 1.5-2.5 hours of labor to get it diagnosed. Repairing it could be as high as $600.00, no worries, i just want it sorted out right, but the bike rides very well, despite this issue. I've read some people just live with the sloppy steering, don't see how...
I'm not sure about the grumble/stutter from the transmission, I can describe it like a cars worn-out automatic transmission almost, as it shudders going into second gear. But after riding it 50 miles today, the grumble goes away if you give it a heavy throttle through take-off, as if its "geared" for a tall first gear, might be inherent to this particular bike or different vsr rollers from stock, I don't know.
The bike (2009) seems to have one owner from Madisonville, LA, purchased in April of 2011.
The bike came with four keys including the master and an extra blue key, I have not found the Security card.
I appreciate the information I've learned from this site and look forward to many happy miles.
James
⚠️ Last edited by jlsworks on UTC; edited 1 time
