mikefrombaltimore wrote:
A) Mazzy Cranks are made from inferior metal
Now, why would they do that? I can't imagine there's that much to save. To me it looks like the flywheel taper bit of the crank has been machined seperatly and just stuck onto the crank web. It doesn't look like the thing is made from the same piece of metal.
I know mazzuchelli cranks had some qc issues, but I always thought that the problem was with the bearings.
B) When running a Long stroke crank and a good pipe it's a good idea to use a lightened flywheel
I don't like lightened flywheels.. besides, the crank taper and right crank web should be the same as on any other regular crank, shouldn't it?
GickSpeed wrote:
now go out and get yourself a Tamini crank.
While waiting for the taxi to come pick me up, I ordered one of those new pinasco long stroke cranks. It looks good and has slightly less aggressive timing, so hopefully it should last another few years.
How did that ruin your top end? Looking at my cylinder it looks fine. I haven't had a chance to inspect the rotary pad yet, but from what I can tell it's a pretty clean cut with a minimal amount of debris.
TCC wrote:
And I bet they were hard, fast and fun kms. in which case I reckon 30-40000 kms out of a kitted motor crank is bloody good going.
Just done its time that's all.
I guess it is. The crank has certainly done its job.. But this happened in the middle of nowhere. Luckily I met a farmer after a while who could store it for me and helped me call a taxi. It cost me a $100 taxi ride and an even more expensive train ticket to go get the car and a trailer and come back and pick it up. And of course I had to give that farmer a bottle of champagne as well..
I just wish there was some way of knowing before hand to avoid this happening again.
