Morning all
It's hot just now and for all you ice cream lovers out there try this - no machine needed - Italian Semifreddo. It's soft, silky and lovely, and VERY easy to make
Semifreddo
3 large whole (preferably organic) eggs
2 egg yolks
1 cup caster sugar
1 teaspoon vanilla bean paste (or 2 teaspoons good vanilla extract)
2 cups double (heavy) cream
Serves 4 to 6
(double up amounts if required.)
Eat within 3 days of making.
Method
1. Place the eggs, extra yolks, sugar and vanilla in a heatproof bowl over a saucepan of simmering water (don't let the bowl actually touch the water!) and, using a hand-held, electric mixer beat for 8 minutes or until pale, thick and can hold ribbons on surface. Remove from heat and let it cool for 5 mins
2. Whisk the cream until soft peaks form. With a metal spoon gently fold the cream through the egg mixture until thoroughly combined. try to not knock too much air out.
Pour into a container, cover and freeze overnight
This is soft and scoop-able straight from the freezer. Eat!!!
Or - if you like flavours to be added, let it freeze for a couple of hours then add your add-ins and put back into the freezer. You need the mix to be a little thicker so the add-in's are suspended and don't fall to the bottom of the semifreddo.
Add - ins
Soak 4oz raisins in three tablespoons rum for a few hours and fold into the mix for rum and raisin semifreddo
Add the finely grated zest of three lemons and three limes and three tablespoons of limoncello for a citrus semnifreddo
Bash up a honeycomb bar or two and add to the mix
Chop chocolate of your choice and add to the mix
Puree a cup of tinned peaches and strain in a sieve, swirl this through with fresh raspberries and bashed up vanilla biscuits (particularly good) for a peach melba cookie semifreddo
Add strawberry or fruit puree of your choice
Melt nutella a litle and swirl through the mix when it's half frozen, and top with chopped toasted hazelnuts when serving
Add coffee essence or extract, or 4 very strong thick espresso coffees and chopped chocolate for a mocha semifreddo
Add mint extract and chopped chocolate for a mint choc chip semifreddo
Use whatever ingredients you like - the possibilities are endless!!
Do try, I hope that you will like this.
Kitty
X
