Sat, 17 Aug 2013 15:04:51 +0000
2010 Piaggio MP3 500
Sat, 17 Aug 2013 15:04:51 +0000 quote
Hello. I just bought this 2010 MP3 500 last month, and already dropped it on it's side while attempting to back out of the garage.
Well, I guess this small drop on it's side knocked the front wheels out of alignment with the steering column.
When I have the handlebars pointed straight, both wheels are pointing slightly to the right.
Have any of you had this problem? If so, how can this be fixed?
Thanks!
Derwin
Sat, 17 Aug 2013 15:17:12 +0000
Sat, 17 Aug 2013 15:17:12 +0000 quote
The 'quick and dirty' method: You can turn the bars fully right against the end-stop, and gently bang them on the end-stop. They should move bit by bit into the correct position.
The 'correct' method: Remove all the gubbins from the handlebars to reveal the central steering-tube pinch-bolt. Undo this half a turn or so, move the handlebars as above, then nip up to the correct torque.
I can't be arsed to do all that, so use the former method...
Sat, 17 Aug 2013 19:22:09 +0000
Piaggio mp3 500
Piaggio mp3 500
Sat, 17 Aug 2013 19:22:09 +0000 quote
The former method works. I know!!
Sat, 17 Aug 2013 20:44:31 +0000
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Sat, 17 Aug 2013 20:44:31 +0000 quote
yep the former method. quick and easy.
Sun, 18 Aug 2013 01:32:16 +0000
Sun, 18 Aug 2013 01:32:16 +0000 quote
I think I may use the "correct" method to fix this, since it doesn't seem to be too laborious.
Thank you, my friends. You helped me greatly, and you saved me a few dollars as well. You can't beat that!
UPDATE: I just took the parts off, and I wanted to make sure that I am tightening the correct bolt.
Is it this one that is being pointed out here:
If this is not it, does anybody have a picture or drawing that could help me?
Thanks.
Sun, 18 Aug 2013 02:41:45 +0000
2007 Yamaha Vino 125
Sun, 18 Aug 2013 02:41:45 +0000 quote
Yep, that's the one.
Helpful hint: once you get the handlebars aligned, make some marks with a black Sharpie so you know where the bar should be if you knock them out of position again.
Sun, 18 Aug 2013 03:06:08 +0000
Sun, 18 Aug 2013 03:06:08 +0000 quote
Thank you VERY much! This fixed it perfectly.
You guys are the best!
Wed, 21 Aug 2013 09:07:42 +0000
MP3 Fuoco 500
MP3 Fuoco 500
Wed, 21 Aug 2013 09:07:42 +0000 quote
i had the same problem recently..
and the steering alignment gotten worse as I ride along, i have like 10-15 degree of wrong angle before I stop the bike in a safe place and put the bike on hydro lock, straighten up the 2 front wheels and using my foot to step on 1 side of the wheel and push the handlebar till its back to the straight up position. (just like how its done on a bicycle)
I will removing the handlebar stuffs and tightened the bolts again before it cause an accident on the move..
had anyone tried changing the handlebar to something else?
Wed, 21 Aug 2013 11:51:12 +0000
Wed, 21 Aug 2013 11:51:12 +0000 quote
finding something else is the problem.
Wed, 21 Aug 2013 13:20:52 +0000
Wed, 21 Aug 2013 13:20:52 +0000 quote
To elaborate on OAD's point, the handlebars on the Fuoco are not like those on normal motorcycles. They don't just get clamped down to the steering tube. They have a portion that clamps on to the (hollow) tube that's welded on.
You could get another set of bars, but you'd still have to figure out a way to attach them. That's where the trouble lies.
Mark
Wed, 21 Aug 2013 15:07:39 +0000
Piaggio mp3 500
Piaggio mp3 500
Wed, 21 Aug 2013 15:07:39 +0000 quote
Check out this thread about reinforcing the MP3 steering column.
Steering tube plugs
Thu, 22 Aug 2013 03:07:47 +0000
MP3 Fuoco 500
MP3 Fuoco 500
Thu, 22 Aug 2013 03:07:47 +0000 quote
got it..
let me do some measurement when i take off the handlebar assembly during the weekend.
from the image, it looks like something similar to a bicycle's setup. (i'm in the bicycle industry)
maybe a bicycle stem and handlebar with some modification could replace the assembly..
could lose the plastic around the steering area and may not look as standard as original..
Mark
Thu, 22 Aug 2013 10:37:49 +0000
Thu, 22 Aug 2013 10:37:49 +0000 quote
Why do you want to replace the bars? They aren't the problem...
  DoubleGood Design
[ Time: 0.0490s ][ Queries: 3 (0.0278s) ][ Debug on ][ 297 ][ Thing Two ]
