Damn, wrote long post and it disappeared while doing attachments.
This one will be short. Did a quick dirty test, here are some numbers....
Average Difference from Under the plug to the Under the Stud #1
9.61 deg F
Average Difference from Under the plug to the Under the Stud #2
12.58 deg F
Average Difference from Under the Stud #1 to the Under the Stud #2
2.97 deg F
Max Difference from Under the plug to the Under the Stud #1
15.52 deg F
Max Difference from Under the plug to the Under the Stud #2
17.61 deg F
Max Difference from Under the Stud #1 to the Under the Stud #2
6.23 deg F
Short on time these days, anyone wanna take this hardware and log some real data? I'll mail ya the HW and the TrailTechs, just mail back when done. Also allows ya to control timing (retard only), has 3 Trail Tech inputs and 1 K-type thermocouple input. I log using my little Asus Eee through USB.
Plots of data and OpenOffice SS attached. Data labeled IAT and TPS are the under the stud TTs. The CHT is for the under the plug TT. The EGT is for the K type, in the exhaust. The TT are in F and the EGT in C.
I did this in a hurry. Tell me if I messed something up.
