@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
OK, I got my racing engine cured and had some time to go around and get things dialed in as far as idle tuning, clutch cable adjustment, etc. One thing I'm noticing is that if I use the clutch to shift to 2nd or 3rd it often pops out of those gears. Strangely to me, if you just shift it no clutch, it usually seems to stay in.
I'm assuming the no clutch shifting is bad for the cruciform, and that my issue is a worn cruciform or selector spring. Am I on the right track? Is there any way cable adjustment comes into this? Neutral shows neutral at the headset, and if anything the cables might be on the tight side but definitely not the loose side.
On a positive note, I got my copy of "How to Restore Smallframe Vespas" today and I see that the whole setup is basically the same shifter-wise as my Lambretta, so I can visualize what's up in there. Seems like a good book on my first thumb-through.
Cheers,
John
SS208, SX250 , RD's and a K1300s and an RZ350 and TZR250
Too tight of cables or friction on any of the cables can cause issues. But you are probably right, it most likely needs a new cruciform and maybe gears...
%$#^@#!. What TR said. My first smallie project gear cable installation had me swearing. Gear jumping in mainly second and third, gear missing, and cold sweat. After adjusting for more slop, it quit. I suppose a little loose allows the selector to rest in the detent with no cable force applied. I settled on adjusting for a little gear grip wiggle in all gears.
Hopefully you won't have to go inside.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Cable adjustments for the win 8) .
[ Time: 0.0081s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
