@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Are the SHB main jets 5mm? I think so and I want to order these for the Primavera:
http://jet200.com/catalog/product_info.php?products_id=432
Can anyone confirm? Thanks.
nothing at all
nothing at all
John. Do you have an old jet in the carb now you can mic to see what size they are?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Yeah Jimmy. Should've done that while the carb was out. DOH!
Jimmy your response also had me thinking DUH I can try one of the Lammy jets for size even though they are all too big as far as the hole goes.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
never mind I found it on the SIP website - yes 5mm
carry on with your Cyber Mondays Razz emoticon
nothing at all
nothing at all
That's cool they are the same size as our 'other' bikes. I had a set of jets for the et3 but included them in the sale.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Yeah the only thing is you are playing in a different neighborhood with stock jets in the 70's so I need to buy the 75-100 kit.
I like to have variety on hand. I haven't seen yet what the PO did for jetting but I like to make them so fat they choke and then back off 1 or 2 sizes. There's a Polini kidney pipe on there so I'm assuming it needs bigger than stock. I try to sort this kind of stuff before I put any real miles on.
nothing at all
nothing at all
That's the grouping I had for the smallframe 19/19
nothing at all
nothing at all
I have a bunch in that group you can have. I think I got them from you with the carb you sent.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
I didn't send you a carb, just that idle jet. Must've been some other dude Laughing emoticon . Let me know what you have when you have time to look.
BTW I see my definition of "kidney" and "banana" aren't the same as everyone else, but it looks like this one:
nothing at all
nothing at all
I'l take a look. Yea, that's a kidney.
Theres a nice baanannaaa on scootnet for sale.
I prefer the later for the stock or stockish 125.
http://scoot.net/classifieds/forsale.html?id=45934
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
If I went to a banana, I would have to go for this:
http://www.sip-scootershop.com/en/products/racing+exhaust+sip+road+ban_24168000
SIP Road banana! I love the SIP Road pipe on my P200.
nothing at all
nothing at all
That one is a huge improvement over the traditional one. The old style you had two bolts that sepaerated the can from the header.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
I knew it! There's a 75 in there, not jetted for the pipe. It just felt lean to my butt air fuel meter.
@mrj avatar
ET3
@mrj avatar
ET3
The ET3 setup I used a 76 with stock banana and the jetting was spot on.
My guess on your Polini pipe would be low 80's, this will greatly depend on your airbox. Is it stock or has been drilled with some steel gauze removed.
Are you running a Primavera top end or kit?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Airbox doesn't show any sign of modification. There's tape over a hole between the mounting studs. No sign of other drilled holes, looks like the material is all there.
I believe it to be a stock 125 primavera cylinder.
I ordered the BGM 75-100 jet assortment, that should cover it. I was guessing 80 but will try a bit higher first. Thanks!
nothing at all
nothing at all
Some 125's came with a 16/16 and others a 19/19. Which one do you have John.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
19/19 Jimmy
nothing at all
nothing at all
sdjohn wrote:
19/19 Jimmy
Sweet.
I had good luck with mine.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
It's basically the same as a Lammy carb, should work fine I think. I like my simple carbs.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
82 didn't rev out cleanly, gonna try an 80 next. That's why I like the BGM kits. No sweat if you guess wrong!
What's up with the 2 prong spark plug connection, is that standard for smallies? Looks like you wrap a fork around the plug end. I'm not inspired to confidence by that type of connection.
nothing at all
nothing at all
If you don't like that old style, which I had on my et3 and it was great, you can order a awesome good cheapo from these guys.
I like the ones that require the nipple on the plug.
https://www.treatland.tv/spark-plug-wire-n-boot-p/spark-plug-wire-n-boot.htm
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
So long as it works well I'll roll with it, it's just different than anything I've seen before. Is it kind of standard with the older bikes?
Thanks for the link Jimmy.
nothing at all
nothing at all
A lot of old bikes had those fork type.
As long as the rubber boot is good condition theyre fine.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
80 feels good. 4th gear feels kinda weak, I wish there was an easier way to tweak gearing. Probably going to have a lot of 3rd action with the hills.
nothing at all
nothing at all
Yes to 3rd and wind that bitch out........your flywheel is your friend.
[ Time: 0.0187s ][ Queries: 3 (0.0075s) ][ live ][ 313 ][ ThingOne ]
