Looks like I signed up just in time!
My ET4 cut out on the way home this evening. Seems like the battery may just have given up the ghost but it was also recently serviced and I know they jet washed it so I'm going to throw a new battery on it tomorrow morning and check the connections are all dry.
The question is, what battery do I need?
Also, are there any common charging issues? Both fuses by the battery are fine and the ignition light (oil light) does come on when the key is turned but dims when you attempt to start it.
Any other suggestions welcome but definitely seems battery/charge related as it was running fine prior to simply cutting out.
