ramblerdan wrote:
Don't forget that in addition to warmth, gloves need to protect your hands in case of a crash.
My winter gloves are
Cortech Scarabs, which have good impact/abrasion protection and are quite warm, especially if used in conjunction with liner gloves. For the latter, I recommend the
Seirus Thermalux. It has a pocket to hold a chemical heat packet and metal threads to conduct the heat. The only drawback of the Thermaluxes is that they stick to Velcro.
Scoot_Florida, can you operate the horn and turn signal buttons with those covers on?
There's a thumb "pocket" that allows you to operate the starter, horn, and turn signals. The manufacturer put a clear "window" on the top of the pocket, I suppose it allows you to see your thumb position (?)
Operating the buttons is not nearly as easy as when bare handed, but about the same as when wearing thick gloves.
The neoprene material is similar to what many "mouse pads" are made of...a dense foam with a nylon surface. The covers form a cocoon of an air pocket for your hands, other than the fabric cuff there is no contact between the cover and your hands or wrists.
It took a few tries to get the gist of using them. Because the covers are so stiff, they hold their shape and getting your hands in (and out) of them is a quickly mastered skill.
