Re: dr ps... higher or lower?
CJ Scoot wrote:
Just installed 12.5 dr pullys pn my 250 removed the 10.5 dr ps after 5000m. Should i get a higher top speed or a quicker line start now??
Yes, no, maybe and perhaps. The problem with roller tuning is that people are looking for a one size fits all, if I do this, this happens, approach. Heavier rollers will often give a higher top speed, but if your motor is tuned, you want to find the rollers that give you the most speed in the power band of your particular motor. If your motor doesn't have the power to pull heavier rollers higher, you will get a higher top speed with lighter rollers. As far as launching, you adjust that via the clutch more than via the rollers. You want to set up your clutch to launch you quickly, usually by going to a slightly heavier set of springs, and find the rollers tht work with your weight and the way your bike is set up to give you the highest top speed. If you weigh 500 lbs, you are going to need a different setup to get top speed out of your bike than a jockey, for instance. If you aren't happy with the new sliders, try half and half, and see if that gives you the best of both worlds. In the ideal world, you would have about four or five different weights of rollers, change them, ride it, see what you think, repeat until you are happy. It takes a while, but in the end, you have the perfect setup for you and your scooter.
