Piaggio mp3 500
Posts: 1312 Location: Longview,Texas 75604 |
Piaggio mp3 500
anybody have an extra 500 dipstick I can modify as a quick read stick so I don't have to wind it in and out when checking the oil level after changing the oil.
No reason that you shouldn't just measure the oil line on the tip of the stick after you have taken it to the full position by the standard procedure first.
You can use that as your guide in future. This method may be a little less reliable than screwing it in because the winding action probably averages out a true level as it goes in. In particular you need to be sure your not just seeing oil that hasn't had time to drain clear of the hole. |
![]() UTC
Moderatus Rana
MP3 250 and 2 MP3 500s
Posts: 22664 Location: Nashville, Indiana |
Moderatus Rana
![]() MP3 250 and 2 MP3 500s
You may want to check this out. Patrick aka OopsClunkThud designed a couple different oil funnels that have built in dipsticks. I had the first one listed for my 250. Worked great. I think the one that will work on the 400 and 500 is the second one listed. "Oil Funnel 500" you may want to verify that with Patrick though.
Go here http://www.oopsclunkthud.com/ and scroll down a bit. Not a bad price considering how handy it is. |
Piaggio mp3 500
Piaggio mp3 500
High Sticky. I actually looked at that today but I cannot see how one would measure the oil level since it does not seem to have a way to be sure it to the proper depth.
Phillip..P. Smith wrote: High Sticky. I actually looked at that today but I cannot see how one would measure the oil level since it does not seem to have a way to be sure it to the proper depth. Is really interesting... EDIT: Didn't realize this was created by a member of this forum... awesome !! ⚠️ Last edited by canopus on UTC; edited 1 time
![]() UTC
Moderatus Rana
Moderatus Rana
When that ring, indicated by the red arrow, is flush with the top of the oil port the dipstick is at the correct depth.
When I used the other one for the 250 I would pour in the oil, remove the funnel and wipe the dipstick then reinsert to check the level. Much easier than doing all that screwing and unscrewing. I need to order one. Kind of forgot about it until this thread popped up. ![]() |
![]() UTC
Posts: 22930 Location: Harriman, Tennessee, Tn |
even easier. just use your oem dip stick. the first time screw it all the way in like normal, look at the level you want to keep it at. Now wipe it clean and just put it in and don't screw it down. check the level, guess what the level never changed its just in a different spot on the dip stick. That is your new full mark now.
![]() UTC
MP3 500 // 91 HD FLHST
Posts: 64 Location: The Hudson Valley- NY - "Always Thinkin" |
![]() MP3 500 // 91 HD FLHST
old as dirt wrote: even easier. just use your oem dip stick. the first time screw it all the way in like normal, look at the level you want to keep it at. Now wipe it clean and just put it in and don't screw it down. check the level, guess what the level never changed its just in a different spot on the dip stick. That is your new full mark now. ![]() |
![]() UTC
Moderatus Rana
Moderatus Rana
My only problem with that method is my aging brain forgets where the new mark is. I would have to make a mark.
Piaggio mp3 500
Piaggio mp3 500
![]() UTC
stickyfrog wrote: My only problem with that method is my aging brain forgets where the new mark is. I would have to make a mark. |
![]() UTC
'09 Mp3-500 - Gone Now
Posts: 2065 Location: Happy Valley, Oregon |
![]() '09 Mp3-500 - Gone Now
old as dirt wrote: stickyfrog wrote: My only problem with that method is my aging brain forgets where the new mark is. I would have to make a mark. |
![]() UTC
BravoTwoFour wrote: old as dirt wrote: stickyfrog wrote: My only problem with that method is my aging brain forgets where the new mark is. I would have to make a mark. ![]() |
![]() UTC
Moderatus Rana
Moderatus Rana
old as dirt wrote: BravoTwoFour wrote: old as dirt wrote: stickyfrog wrote: My only problem with that method is my aging brain forgets where the new mark is. I would have to make a mark. ![]() ![]() |
![]() UTC
sanogeo1 wrote: Must get that vision out of my mind ![]() |
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8954 Location: Ashburn, Va. Home to the Internet |
old as dirt wrote: even easier. just use your oem dip stick. the first time screw it all the way in like normal, look at the level you want to keep it at. Now wipe it clean and just put it in and don't screw it down. check the level, guess what the level never changed its just in a different spot on the dip stick. That is your new full mark now. |
Piaggio mp3 500
Piaggio mp3 500
] Oil Funnel 500. oops has this oil funnel for a 500 listed. I ordered the funnel. They sent me a note saying they were making a 3d diagram. I thought they were making me a 3d picture of a funnel. I will get a real funnel. They actually have a process of manufacturing that is amazing!! Check them out even you do not need to purchase anything! |
![]() UTC
Phillip..P. Smith wrote: Oil Funnel 500. oops has this oil funnel for a 500 listed. I ordered the funnel. They sent me a note saying they were making a 3d diagram. I thought they were making me a 3d picture of a funnel. I will get a real funnel. They actually have a process of manufacturing that is amazing!! Check them out even you do not need to purchase anything! I just ordered up one of these spiffy funnels... |
never knew of this item. bought the funnel and plastic muffler gasket case. It can be so easy to damage sitting in the garage parts bin.
![]() UTC
So I bought both the engine oil and hub oil filler funnels / dipsticks. I have yet to try them out but they look like they will work well. Initial thoughts:
- Since they are 3D printed the surfaces inside and out, are rough. They will hold oil, and thereby contaminants, after using them. They'll need good cleaning after use. - The engine oil dipstick is reasonably smooth and has good markings. The hub oil dipstick (on the right in the photo) has numerous molded-in characters - both inset and proud - that will make wiping it off to read oil levels rather difficult. The level markings are not quickly distinguished. - Cannot speak to their strength. Seems like the plastic is a bit brittle, but time and use will tell. ![]() Just noticed cat hair in the pic. Seems like it's EVERYWHERE this time of year... which would be a much greater concern if there wasn't a cat lurking in the house! . . . . |
