What you guys using?
I found that Craftsman Tool sells this one.
http://www.sears.com/schwaben-brake-bleeder-wrench/p-00940578000P?prdNo=5&blockNo=5&blockType=G5
![]() 2009 MP3/250, 2012 GTS Super 300ie
Posts: 4309 Location: Marietta, GA |
I found that Craftsman Tool sells this one. http://www.sears.com/schwaben-brake-bleeder-wrench/p-00940578000P?prdNo=5&blockNo=5&blockType=G5 |
That's a nice looking wrench. I've been using an ordinary 6-point box-end, since the MP3 bleeders don't need a ton of torque, nor do they present a clearance problem. Avoid 12-pointers for this.
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8954 Location: Ashburn, Va. Home to the Internet |
WEB-Tech wrote: Not needed, that is for hard to reach bleed screws. Regular 6 point wrench works fine. I have a 3/16 clear hose on the bleeder nipple going to a one-way valve through another hose to a trash water bottle. Need a easy way to open to bleeder, squeeze the trigger multiple times and close. I didn't have a good 11mm wrench to do this. The one I did have is an open end wrench and you really can't get a good hold to open and close on the front of the MP3/250. So this one at Sears looks like it will solve my problem it is bent to get around the MP3/250 obstructions. I hope? I will find out when I get it and try it... My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? I wish there was a replacement bleeder where these can be replaced. Keith |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 45152 Location: Pleasant Hill, CA |
klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? |
jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? |
![]() UTC
Posts: 22937 Location: Harriman, Tennessee, Tn |
WEB-Tech wrote: jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? |
old as dirt wrote: WEB-Tech wrote: jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? Thanks, Keith |
![]() UTC
klaborde wrote: old as dirt wrote: WEB-Tech wrote: jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? Thanks, Keith |
old as dirt wrote: klaborde wrote: old as dirt wrote: WEB-Tech wrote: jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? Thanks, Keith Scooterwest has a video doing similar with a bleede R that is preasurized witha air compressor. They have to meep sucking out the resovoior. I didnt know you could do same with a syringe. |
![]() UTC
klaborde wrote: old as dirt wrote: klaborde wrote: old as dirt wrote: WEB-Tech wrote: jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? Thanks, Keith Scooterwest has a video doing similar with a bleede R that is preasurized witha air compressor. They have to meep sucking out the resovoior. I didnt know you could do same with a syringe. |
old as dirt wrote: klaborde wrote: old as dirt wrote: klaborde wrote: old as dirt wrote: WEB-Tech wrote: jimc wrote: klaborde wrote: My observation, the minute you open up that bleeder, you can get air back into the system through the threads possibly? Thanks, Keith Scooterwest has a video doing similar with a bleede R that is preasurized witha air compressor. They have to meep sucking out the resovoior. I didnt know you could do same with a syringe. |
