Nexus 250
Nexus 250
Hey guys. Forum Lurker here!
I'm having an issue starting my Gilera Nexus 250 (Quasar engine)
I was riding home one day and I stopped for 5mins to grab some food. Jumped back on the Nexus and it refused to start.
It wasn't turning over. Just a quiet click sound when you hold the brakes and press the starter.
The click sound comes from the fuel pump area.
Had to push it home.
I've charged the battery again. Still not working.
What I know;
- The battery is 6 months old and I fully charged it 2 weeks ago for winter.
- Battery was charging fine at 14.5volts while riding so reg & rect are fine.
- I've tried both keys (inc master)
- Immobiliser lights with the master key show ok.
- All fuses are fine.
- The bike isn't even trying to turn over.
- Fuel pump sounds fine when I turn the key.
- Brake lamps do light up when pressed.
I'd greatly appreciate any ideas of what to check and how.
Could it be the starter coil?
Gilera Nexus 250ie sp 2007
14,000 miles
⚠️ Last edited by P187 on UTC; edited 2 times
The click you hear is the starter relay 'making' contact - or in your case not the 'making' bit, as probably the relay contacts inside have become pitted and dirty. You can open it up quite easily to clean them, but new relays are cheap enough. It could also be a bad -ve connection to the frame, or a bad crimp on one of the main cables to/from the starter relay, but the relay itself is the most likely culprit.
Nexus 250
Nexus 250
Hello JimC, thanks for the quick reply!
Could it be to do with this red connector?
It's seriously gopping! Looks like it's completely covered in oil? WTF.
Uploaded with ImageShack.us
Not the red thing in the middle of that picture - but see the two big red cables? That's where they join onto the starter relay, mostly hidden in the pic. Check they're clean and secure.
Nexus 250
Nexus 250
Will have to clean it up later when I have time to pull the panels off.
I'll be soo happy if this is resolved just by cleaning a friggin connector.
Might also zip tie some cable sheaf around it as bit of preventative maintenance.
Cheers pal. Will let you know how it goes.
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Could be a failing fuel pump. Can you hear the fuel pump running when you turn the ignition on?
@roadster avatar
Kymco AK550
@roadster avatar
Kymco AK550
You should check the starter relay just as Jim says.
It should be possible to operate the starter by shorting across the two main terminals, the heavy duty one from the battery and the heavy duty one going to the starter motor terminal, watch out for sparks though. If the starter still doesn't turn over then the relay is not the problem.
If the relay is OK then your next move should be to check the starter motor brushes. Try tapping the body of the starter with a small metal object, this will often move the brushes enough to get you going in an emergency.
The brushes on my 250 quasar wore out quickly due to oil contamination creating a sort of grinding paste in the armature housing.
Regards Roadster
@nomad68 avatar
Back on a 125cc!
@nomad68 avatar
Back on a 125cc!
Premises187?
Are you the legend from YouTube?
Nexus 250
Nexus 250
Re: Premises187?
Some really helpful stuff here guys, thanks!
First I'll try using jump leads from a car to see if the battery is dud.
@GTdespatchcourier
The fuel pump does prime when I turn the key (sorry should have mentioned).
Premises187, I am
Legend, naa. Just an idiot with a camera on a bike.
⬆️    About 3 years elapsed    ⬇️
Gilera nexus 300I not starting when hot
I had a gilera nexus 300i and I'm curious as for first time created a problem which is not clear at all what might causing this,it starts just fine when its cold.After i drive it for 5 minutes or more and gets to running temperature and i switch off the engine,when i try to start it again its spinning but not start the engine!! please help
[ Time: 0.0163s ][ Queries: 3 (0.0089s) ][ live ][ 313 ][ ThingOne ]
