@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
I opened up an engine to strip for a rebuild and noticed the clutch was something I've not seen before. It is a 6-spring basket like on non-200 Vespa engines, but it uses 7-spring clutch corks.
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
that looks like the old clutch that came out my engine. sent it off to Gene at Scooters O for a rebuild. he said it was from a GS 160, and SS 180. now I have a P200 clutch except for the Rally 180 gear.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
If it is a GS clutch that would explain why I'm unfamiliar. There are a few models of Vespa I don't work on and that is one of them.
@oopsclunkthud avatar
3:5
The GS/SS have a taper on the clutch side, so that can't be it (assuming this is not a GS/SS). But I think the bell may have been the same between the SS and Rally 180. So my guess would be that this is a Rally 180 clutch, but I've only been into a few and that was a long time ago.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
Patrick, yes this is a Rally 180. The last couple I've worked on had traditional P200 clutches.
@die_wespe_kind avatar
'04 Genuine Stella, '03 Vespa ET, '62 Motovespa 150S (with a P125X engine), a '71 Rally 180, '57 Lambretta LD125 Mk. III
The clutch on my Rally 180 had the same clutch.
@fastfrog avatar
PX125,200, T5, SS180,TS125 and some more...
@fastfrog avatar
that's a GS/SS basket probably fitted on a standard non tapered baseplate...
nothing at all
nothing at all
Can you loose the hair but leave the dirt........top right.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
This was a filthy fucker alright. I cleaned it all yesterday and put new seals in it. I'll get back to finishing on Sunday after seeing the Book of Mormon musical.
nothing at all
nothing at all
That's what Sundays are for......right?!
I heard when they made On Any Sunday that that was their original message.........but Mcqueen didn't like it.
3:5
Remember to fast, this is the first sunday of the month.
@scooterraton avatar
2 - Many
2 - Many
I thought it was a GS or SS clutch at first but now I'm happy that I sat back and watched.
Just curious about a couple of things. How else is it similar to the GS/SS? Do you need a clutch puller tool to get it off? Does it have a brass bushing or 40 roller bearings?
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
It is a typical clutch other than its outward appearance.
@rob_hodge avatar
@rob_hodge avatar
it's an early - to - mid rally 180 clutch. uses larger diameter springs. nothing unusual, except the fact that most haven't seen one as it's not as common a model.
it's documented in the parts books. most parts are available, but if you don't want to run down the parts specific to that style (basket, springs, cups and backplate) 7-spring ones can be swapped. the cups, basket and springs are in common with the SS180, but the GS160 style is different as it is a six spring using the standard smaller springs and it is the larger diameter outer diameter and not the smaller diameter six spring commonly seen on 125/150's until 1985.
if you plan to swap in a later style assembly, the standard setup is more like a 150 primary gearing wise, with 22 teeth, although you can up gear to a 200 23/65 combo, it'll pull it. especially if you overbore or swap to a 66.5 200cc setup.
[ Time: 0.0129s ][ Queries: 4 (0.0028s) ][ live ][ 313 ][ ThingOne ]
