@3wheeler avatar
2009 MP3 500 Red
@3wheeler avatar
2009 MP3 500 Red
Is there any way to change the center digital display to read MPH instead of outside temperature?
I could care less of the temp but what a great added value if this could display MPH or KPH.
Has anyone looked into this?
I really dislike the small MPH numbers on the speedometer
@olestra avatar
2009 Piaggio mp3 500ie "Ephie"
@olestra avatar
technically, anything is possible...
It conceivably could be done by tapping the output of the speed sensors, then running them through a microprocessor (ATtiny probably), then outputting the equivalent voltage that the temp display expected...
so if someone had the specs for what exactly the sinewave output of the speed sensors was and the volt range of the temp sensor was, I could write a program that could convert.
I wouldn't want to be the beta-tester, though.
*tapping into the speed sensor without causing a volt drop big enough to cause faults would be the biggest problem.
the 'simpler' method of just reprogramming the dash -- pretty much impossible without access to the source code.
@bravotwofour avatar
'09 Mp3-500 - Gone Now
Muckin with the display could cause unexpected results methinks.
Get a new GPS, cheap and accurate. Could even be permanently installed.
Or install a separate speedometer like G03 did wayback...
Speedo MPH correction visual
@mckee avatar
MP3 400
@mckee avatar
MP3 400
See here: Fuzzy washer, Dr.Pulley, J.Costa comparison, with numbers - this is Piaggio X8, but same could be done on MP3. Note: blue clock is added screen of his self-made computer. What is on the display o's totally up to the owner/developer. As I remember Veeteck also posted some movie of his computer/clock on YouTube.
In my opinion its easier to dismantle your display and change clock's background (I am sure I saw this mod for MP3 somewhere but not remember if it was on ModernVespa or somewhere else).
In the same way you could change color of background lights too.
Personally I prefer original MP3/400 (European) clocks - different from MP3/500.
PS.: Link to the computer/speedometer: http://www.telwis.pl/universal-trip-computer-utcomp-p-119.html?language=en
@web-tech avatar
@web-tech avatar
Since it's all mounted to a PCB, not sure how you would "tap the output" while preventing input from the PCB?
It may be possible, but in no way is it feasible.
@olestra avatar
@olestra avatar
Cut speed sensor wires, so that instead of going where they are supposed to, they go to original connection and to your micro-controller. Cut wires from temp sensor, hook output of micro-controller to those.
the actual hardware and wiring would be relatively easy. the bugger would be coding and fail safes.
code side, would would need to read digital in fast enough to know how fast the tire was turning : __---__--- versus _-_-_-_ if your controller doesn't read fast enough all you get is steady voltage that cycles up and down at a rate harmonic to the actual pulses.
from there you map the speed of pulses to a real world speed, after which you output analog voltage that is what the display expects for that 'temperature' --the speed you want displayed.
fail safes would include making sure your controller doesn't send out weird signals/ surges during start-up -- that could fry stuff. also checking if the bike uses that external temperature sensor for anything else -- It might use it for a sanity check on the mass airflow sensor on the intake.
and then there is EMI, vehicles are notoriously 'noisy' electromagnetically, making sure you controller doesn't die or go strange from the interference would be fun.
so definitely doable if you've got an EE buddy, or are a really confident amateur. I'm neither, I've built a few robots and a 3d printer, but for something that could go that badly, based on unpublished specs and components... that's a bunch of nope for me, I'll stay with my stickers on the speedo display.
//thank you for the fun thought exercise, though!
@funkymonkey avatar
MP3 500
@funkymonkey avatar
MP3 500
suggestion.
go on Amazon, they have speedometers that works using GPS and can be places on your dash under your windshield, where the image of your speed can be seen on the inside of your windshield.
This way you never have to take your eyes off the road.
http://www.amazon.com/Head-Up-Display-Speedometer-quick-installation/dp/B005X4QCAA/ref=sr_1_1?s=automotive&ie=UTF8&qid=1386489665&sr=1-1&keywords=gps+speedometer
@scoot_florida avatar
2009 MP3 250
2009 MP3 250
While we're talking the realm of possibilities, you could also consider a wireless bicycle computer. They normally consist of a sending unit which works off a magnet attached to the rim and a receiving unit. Both are normally 1.5 volt. The computer (typically) can be programmed for any wheel circumference.
@3wheeler avatar
2009 MP3 500 Red
@3wheeler avatar
2009 MP3 500 Red
FunkyMonkey wrote:
suggestion.
Im going to check into this GPS heads up display.
I think this might be an option to consider.
@web-tech avatar
@web-tech avatar
Like I said, not feasible, if you have enough time and money you can do anything, but why? There are much easier ways to get a digital display.
[ Time: 0.0142s ][ Queries: 3 (0.0084s) ][ live ][ 313 ][ ThingOne ]
