BFR wrote:
what do you mean by a low noise is it a rattling grinding whining??? also any other symptoms is the clutch releasing fully? not dragging.
I assume the gearbox has oil in it?.... have you had the engine apart??
Its more of a whining and not so apparent unless one carefully listens. Clutch engages smoothly and no drag.
Still haven't had the chance to check the gear oil. Am just trying to evaluate the state of the machine by doing a few occasional runs and splitting the engine is certainly in the cards - in about a month or so.
rob hodge wrote:
It's worn crankshaft bearings.
As they wear they get loose. When you pull the clutch lever, it compresses the clutch witc,h pushes on the main bearings, pushing them to one side and taking the slop out of them.
It's not necissarily the end of the world, nor worth srripping the engine just for that issue. Ple nty of vintage bikes have the same issue and as long as you take care of the engine andrun the propper oil mixture it rarely escalates or gets worse.
Although I work on my motorcycle, scooters are totally new to me and what you say does make sense. But my idea is to turn the scoot into a fair bit of tourer that can do decent speeds. So my question is, with the engine untouched, can I ride it at speeds of 70-80kmph? Would it survive the stress?
Thank you all for you inputs!
