12
Im restorating my Vespa Cosa and I need some help from you.
![]() red mark. is there coming gas or oil?
![]() red mark. is this panel remowable or not. I already remowe the screws
![]() 2013 GTV 300 ie "Victoria" Concept 2 Model D "River of Pain"
Posts: 1383 Location: Aurora, Ontario Canada |
Welcome to Modern Vespa! I hope you find the forum as useful and as friendly as I do. I can't answer your questions, but I am sure that someone will be along in a few minutes who can, and will probably move this post to the Not-So-Modern section of the forum.
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 44954 Location: Pleasant Hill, CA |
![]() '74 50s x3 '87 PK125XL '92 PK50XL2 Plurimatic - & - '58 AllState '68 Sprint '66(?) 125 Super '72 DanMotor 150 Super and '04 Bajaj LML hybrid
Posts: 10046 Location: seattle/athens |
1 No, that's the throttle cable, the oil line is just above it. The gas line comes from underneath at the back of the airbox.
2 No, the screws are only for removing the plastic floormat, you have to get at the hydraulic brake stuff from underneath and it IS a bitch. PS Got your message & just sent a reply Good luck |
![]() PX125,200, T5, SS180,TS125 and some more...
Posts: 204 Location: Paris, Taxes! |
fastfrog wrote: your cosa is in a really bad shape mate... Are you really gonna restaure it? |
V oodoo wrote: 1 No, that's the throttle cable, the oil line is just above it. The gas line comes from underneath at the back of the airbox. 2 No, the screws are only for removing the plastic floormat, you have to get at the hydraulic brake stuff from underneath and it IS a bitch. PS Got your message & just sent a reply Good luck so i have two line, one is oil and a second is gas line, so im having a automatic gas mixure. and im missing a oil tank.... i must get it. NEXT problem: how to remove a steering. i tried to remove the muter with a hammer and screwdriver. its a left or right turn? guys, thanks for now |
Quote: your cosa is in a really bad shape mate... Are you really gonna restaure it? Not sure if OP is gonna really 'restore' or just get it running & presentable. Either way, I see he's gonna need a brake fluid resevoir(mounts just in front of the gas tank). The nuts on the fork stem unscrew counter-clockwise. There should be 2 of them with a tabbed washer in between. Use some pentrating oil & let it soak in first. |
the french Bible:
http://www.vespa-des-savoie.com/restauration/PX_COSA/revue_technique_vespa_PX_COSA.pdf |
and where is his place? next to gas tank is a 2T oil tank lined to the carburateor or not?
so if i understand correctly there are 3 tank. one is gas tank, second is 2T oil tank, and a third is a brake fluid tank. And all 3 are placed together? Some picture please, on page 58 i dont see anything
Fastfrog i allready have everything in control voodoo sent me pics and now i have a picture in my mind
sandi125 wrote: how to remove steering keylock? if i dont remove it i cant take the plastic box down Or you could cut away the crappy plastic glovebox & afdapt a P series metal glovebox to fit... ![]() Here's mine that was donated by a 2004 Stella. Any luck finding the oil & brake fluid tanks? ⚠️ Last edited by V oodoo on UTC; edited 1 time
V oodoo wrote: sandi125 wrote: how to remove steering keylock? if i dont remove it i cant take the plastic box down Any luck finding the oil & brake fluid tanks? yes i have any offers for tank, the question is the price and shipment |
Did I miss something?
I wanted to see how also, but on Page 60 all I saw was some Cosas & a P w/ big fat windshields and a lot of French words.
Wrong page or did I overlook something. Mr Frog? Maybe you could tell us what says on page 58, there's some kind of pic there. but not really enuff to figure it out. |
P60 not 61.... I guess numbers are the same in our 3 languages...
P58 deals with how removing and renewing master cylinder. |
I allready figure it out. I have to remove all eletric cables and then i have place to come to the cilinder. Theres one tiny shift and then the lock came out
Check uour cylinder head: if its a standard px head : serie1, if it's a central conical shape: serie 2....
how to remove that anoying plastic where ale the installation and cabels are coming from back to front edge?
and also how to remove the air filter? ![]() |
its marked with red arrow. the plastic that shuts the hole that leads under the frame an then to the front of the vespa
