Ok, so I finally got around to changing the rollers on my GTs 250 ie. Unfortunately I didn't get off to a good start- when trying to remove the Air Filter Box from the engine I sheared-off the two rear screws
. What's left of the middle screw is still holding the air filter box onto the engine as there seems to be some clip at the rear holding it. With great difficulty I still managed to get the transmission cover off.
So my question is- do I really need to try to get what's left of the two screws out & replace them? The front one is still good & as above the middle one is still holding the Air Filter Box, so really it's only the rear screw is missing. If I can get away with it it would be preferable to buying an "easy-out" set & messing around with drills etc. Any thoughts?
