The Vespa GTS 250ie is an uncompromising fusion of breathtaking performance, technical superiority and classic Vespa design. The GTS 250 has 12" alloy wheels, front and rear disc brakes and a liquid cooled engine with electronic fuel injection. Asking $3,000 OBO. Serious buyers only. No checks. Scoot is located in Valley Village / North Hollywood, CA 91607.
Registered and clear title. Average fuel mileage, 70 miles per gallon.
Average top speed is 73 - 76 mph. This depends on your average height and weight.
Mileage: 7100
GTS stands for Granturismo Sport, while the 250ie is the displacement and electronic fuel injection.
Year 2009
Manufacturer Vespa
Color Red
Model GTS 250ie
Vin # ZAPM459L095008212
Engine Type Single Cylinder
Engine Displacement 244cc
Bore & Stroke 72mmx60mm
Compression Ratio n/a
Cooling Liquid
Fuel System Fuel injection
Ignition Electronic
Starting System Electric
Transmission Automatic
Final Drive n/a
Rake and Trail n/a
Wheel Base 54.9 in.
Seat Height 31.1 in.
Front Suspension Single sided trailing arm, dual chamber hydraulic shock, coaxial spring
Rear Suspension Helical spring adjustable four position pre load and two dual effect hydraulic shock
Front Brake Disc brake
Rear Brake disc brake
Front Tire 120/70-12 in
Rear Tire 130/70-12 in
Fuel Capacity 2.4 gal
Dry Weight 326 lbs
MSRP $5,999
I have taken excellent care of my Vespa. In 2012 I slipped on oil in the parking garage and dropped her, she has a scratch on the side fender. I took her to the repair shop and they checked her out and said it was just cosmetic damage. She's also about due for a new front tire. I have a Vespa Mechanic that I take her too. I would be more than happy to give you his number so you can talk to him about the Vespa GTS250ie.
"As Is" - No implied warranty of merchantability.
818-395-6950, please text, call or email.
