@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Does the ET3 top end use the same cylinder head as the earlier primavera engine?
I'm assuming I can drop an ET3 cylinder on my stock lump, re-use the cylinder head, polini kidney, and 19mm carb. Probably have to drop the timing back to 20 degrees like ET3 used? Is that it?
Scooterworks has the kits on Ebay for ridiculous prices, with free shipping. I figured it was too cheap not to have a look.
-John
nothing at all
nothing at all
I have these pics for reference.
Ive used both stock head and primavera.
Always check squish.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
John,
Just toss that barrel on. Using same piston?
You'll have to do your timing over and such; TDC may change due to different piston.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
I was assuming using the new piston, I have no idea what is in my Primavera cylinder.
Time it like an ET 3 or a primmy? I wasn't sure. I figured ET 3 20 degrees.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
Yes, like an ET3. Do you have an ET3 primary set? If so, you should move on that. I've got a few stashed away.
nothing at all
nothing at all
Chris is better at this shit than I am but I have a question.
Did you ask marcus if he ever oversized the piston. Hes had it a loooong time and so you should measure your piston or unfortunately you have to order a new piston to go with the barrel. If it a stock piston than it should be fine witht he new barrel and your old head.
Get it.....old head!!! Im f'n funnee dude
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Barrel comes with a new piston too:)
nothing at all
nothing at all
There ya go. Done and done. Check the champer and squish.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Chris theET3 had different primaries?
nothing at all
nothing at all
If hes not gonna answer you I will.
Yes.
there in the 20something/60 soething.
The gear stack/cassette is the same but the primarys vary from bikes. The et3 sahares the same as others and the primmy shares the same with others.
Maybe chris knows exactly the primary numbers.
But I wouldn't worry about that shit right now. Youre looking for more oomph for a hill the barrel swap will be a good start.
@mrj avatar
ET3
@mrj avatar
ET3
An et3 and primavera have the same primary ratio: 24/61 helical cut gears (2.54).
The et3 cylinder head has a slightly different head over a stock primavera. The et3 head looks like pic #1 in Jimmy's photos, its very similar to a polini style. It has a wider squish band and smaller combustion chamber over a stock primavera. I would think it has a slightly higher compression ratio. Photo #2 & #3 are primmy style heads.
Timing on et3 is 20º and primavera is 24º.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Now that makes sense - the higher compression ratio is the reason for the timing change. 8.2:1 vs. 9.25:1
[ Time: 0.0100s ][ Queries: 4 (0.0020s) ][ live ][ 334 ][ ThingOne ]
