GTS 300 SS
GTS 300 SS
I have recently purchased a new Super Sport, which currently has about 1000km's. On about 5 separate occasions at constant speed the rev's die for a split second... Other than this, my wife and I love the scoot.
Does anyone know what this could be?
(Not a big issue as I am taking it in for its first service soon, so will get the shop to investigate)
@nomad68 avatar
Back on a 125cc!
@nomad68 avatar
Back on a 125cc!
2012 gts 300 super sport engine dyeing
Have a read of this....
There are loads of threads about this, mine does it too
GTS 300 SS
GTS 300 SS
Thanks spike 68, once you get past the pom' having a dig at each other, there is some really useful info.
@nomad68 avatar
Back on a 125cc!
@nomad68 avatar
Back on a 125cc!
Have a search around on here and on the net, it's a problem loads of gts's are having
TWONK yup that's MV. A warm aloha and welcome to the forum from Hawaii. Good luck with your problem.
Sounds like its one of the new G3 ecu models that had bad software, so needs a remap session...
@bill_dog avatar
eeeee bip
BMW R1100RT The Problem Child Kymco Downtown 300 - I'm not the Uber Honda Cub - Scorched Earth Policy
eeeee bip
@bill_dog avatar
target
One of many I fear.
Mine included.
Bill X
GT 2.4
GT 2.4
In Italy, they tend to program the ecu so that it flattens out at the rpm level the ECC checks noise levels at. Ducatis and Moto Guzzis were notorious for having a flat spot at 4000 rpm because of this. Sometimes it doesn't work out quite so well in the long run.
GTS 300 SS
GTS 300 SS
Thanks folks, at least i have something to discuss with the mechanics on Thursday!
@david_masse avatar
@david_masse avatar
I had a similar intermittent problem with my 2010 GTS 300 i.e. Diagnostic finally kicked out a fuel injector fault. Installed a new injector: problem solved.
GTS300
GTS300
I had this happen to me for a split second this morning. The check engine light went for for about that same second then it was gone and it was like nothing ever happened.
I've had this happen to me about 3 other times now and i'm at 4k on my GTS.
Seems to only happen at speeds over 70mph for me though and mostly over speeds of 80mph.
This was the first time it happened at less than 80mph.
GTS 300 SS
GTS 300 SS
Took the scoot for its 1000km service this morning and they have uploaded new ecu software, so far so good....
[ Time: 0.0271s ][ Queries: 4 (0.0184s) ][ live ][ 313 ][ ThingOne ]
