So I had an ET4 for a couple of months. It has always been a bad starter. It will not start at all from the kick start. Sometimes it starts straight away - but if I am not careful it can die again, and then it is hard to start again. However, whenever it is started, I have to twist the throttle back slowly until revs build, if I do it too quick it will die. Even while riding, if I let the revs off to slow down and then go to pull away quickly the engine can cut out - so always need to be gentle with throttle which is not good at junctions when I need to be quick off the mark etc.
To top it all, I tried to start it yesterday, and it started straight away, but then it died and would not start again, I ended up draining the (fairly new) battery. I had the old battery fully charged spare so I popped that in. I then tried to start it and after turning over a couple of times the starter stopped completely. The lights etc all work and when pressing the start button I can hear the switch next to the battery - but that's it.
I did notice the battery had water condensation on it. Have I shorted something?
Really grateful for any help. Cheers
J
