Doesn't seem to matter what I search for, it doesn't match any criteria.
What am I doing wrong? I'm trying to wire a source for my Garmin Zumo and am just looking for the proper routing
What am I doing wrong? I'm trying to wire a source for my Garmin Zumo and am just looking for the proper routing |
Try text without quotes. Even not logged in it still works for me. In fact I just tried it and all was good.
![]() UTC
Posts: 22935 Location: Harriman, Tennessee, Tn |
Re: Help with search
doxbike wrote: Doesn't seem to matter what I search for, it doesn't match any criteria. What am I doing wrong? I'm trying to wire a source for my Garmin Zumo and am just looking for the proper routing there are a few threads on installing a fuse block or power block up front. just a couple I selected Better Fuse Block Electrical Help - Need an accessory wire to tap into (12V) Loong weekend and winter nights full of mods... the last one is one of the first by luthorhuss. |
![]() UTC
MP3 500
Posts: 1422 Location: Arlington, Republic of Texas |
Also restrict your search to only the MP3 form.
But if you want all scooters on MV then dont restrict your search to just the MP3s. |
The trick is to use general terms, not specific, and avoid spellings that exclude rather than include. For example, if you're looking for a thead about wiring, there's a good chance it will talk about at least one "wire"; but it may or may not contain "wiring" or, for that matter, "wires." ("wire" is part of "wires," but "wires" is not part of "wire.")
Or are you saying that there is something wrong with the Modern Vespa search page, and no matter what you do you are getting no hits? That's another tip: when asking for help, be as specific as possible so fellow members don't go off and give advice on something else. So when searching, be general and terse; when asking for help, be specific and detailed. ![]() Note the two generic, and generically spelled, search terms.
![]() These may or may not be what you are looking for, but at least I've got hits.
![]() UTC
Moderatus Rana
MP3 250 and 2 MP3 500s
Posts: 22671 Location: Nashville, Indiana |
Moderatus Rana
![]() MP3 250 and 2 MP3 500s
What jeff said. Also, I will usually try searching message titles only on the first try. Let unrelated results to look through and it works surprisingly well. But not always.
Also, since MV is ranked so high in search engines sometimes a google search will bring in better results for topics here. |
jfolander wrote: I had the same problem, couldn't see the upper box, are you a Mac user? |
>I thought maybe 'cuz I had just joined
No, there's apparently something else going on here. One of the mods will no doubt send a PM to Jess on this. Even if you just joined, even if you are not even logged in at all, you should see the same search fields: ![]() Logged in...
![]() ...and not logged in so I could be anybody.
