![]() UTC
1980 Vespa P200e - 1962 Lambretta TV175 - 1977 Vespa Rally 200 - 1990 Honda S50
Posts: 392 Location: South Florida, USA |
![]() 1980 Vespa P200e - 1962 Lambretta TV175 - 1977 Vespa Rally 200 - 1990 Honda S50
Ok guys... I had a spill. Went over a median grass. Bent the back rim bad. Change the rim the next day with some help from a good friend and some clutch adjustment I rode it home no problem. It been more than a week but I have notice a strong pinging from the top. I don't remember hearing it before. I got lots of help from John "Scooterraton" with the front wheel that was really shaky when I brake. I might be a bit shaken but I kinda think is stronger pinging than I remember. Here a short dark video of the sound. Please advise what you think of the noise.... Thank you.
RIP
sorry to hear this..the video won't play for me.. says "this video is private"
Glad you're ok |
![]() 59 Vespa, 65 Vespa, 66 Vespa, 57 Vespa
Posts: 1322 Location: Portland Oregon |
![]() UTC
![]() UTC
Vader19 wrote: sorry to hear this..the video won't play for me.. says "this video is private" Glad you're ok |
Rodger, check simple things first, fan shroud, bolts, exhaust pipe, etc.... Then work you way in. Glad you're ok. Good Luck
probably loose tin or shroud bolt or exhaust lead pipe / spring
start by removing / tightening all the bolts and nuts, look for a loose spring, shake exhaust with it off bike could be a loose baffle seat latch bolt within the frame if the crank is going you might get a sound but that is hard to hear stator bolt could be coming loose could be rubbing on flywheel look around remove parts you shall find the issue |
Either fan cover or your cush springs spread open the plates thst cover the cush gear assembly on the layshaft.
![]() UTC
Sounds like it coming from the muffler... Didn't have time to get it off last night but the next suspect is the flywheel. I am riding to work and back very slow (35-40 mph). Power is there and just that new sound for now. Again two new dark videos .... Today I take the muffler off.
Your exhaust stub could be loose/damaged. Or the exhaust could have come free and it is simply being held in place by the mounting bolt.
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Posts: 609 Location: Atlanta |
I would remove the flywheel and check for a sheared woodfruff key. If the flywheel impacts anything, even grass, it could be enough to shear a key and it would make your timing off.
bodgemaster
![]() 63 GL, 76 Super (x2), 74 Primavera (x2), 79 P200, 06 Fly 150
Posts: 7380 Location: So Cal |
Re: Pinging noise....
roggerdavid wrote: Ok guys... I had a spill. Went over a median grass. Bent the back rim bad.... |
![]() UTC
Well I check the scooter and the only thing out of place was the mirror and the windshield a bit. Checked the underside and could not see anything scratched or rubbed. The scooter fell on it left side ( battery side ). The front rim was a tad bent and the back rim was completely bent that you can see the tube.
Attached is a doodle idea of what happened with a pic from the actual place from google maps. ![]() |
rubber grommet round the rule tap rod could be lost
that makes a bunch on racket if not there |
RIP
I'm still dopy but that sound sounds like sometthing flywheel related to me.. especially when it stops in the 2nd video.. I hobbled out to the garage and wiggled all my flywheels and they don't do what yours does.. they move but are tight and don't clack..
So.. IIWY I'd take the flywheel off and have a look at everything you can. Good luck.. and god bless the grass median! |
VADER ! So they finally let you go home from the hospital ! I'm happy for you man, now it's time to heal up. Sorry for hijacking the thread Roggerdavid.
never saw the 2nd vid
that side bearing seems shot replace it asap or the rotary sealing surface shall get f**ked up... then parts of the stator / coils are going to get rubbed on and messed up also. be safe with the flywheel off you can do the same test via the crank taper |
![]() UTC
Vader19 wrote: I'm still dopy but that sound sounds like sometthing flywheel related to me.. especially when it stops in the 2nd video.. I hobbled out to the garage and wiggled all my flywheels and they don't do what yours does.. they move but are tight and don't clack.. So.. IIWY I'd take the flywheel off and have a look at everything you can. Good luck.. and god bless the grass median! ![]() ![]() ![]() Thanks again for the info. |
![]() UTC
spiderwebb wrote: never saw the 2nd vid that side bearing seems shot replace it asap or the rotary sealing surface shall get f**ked up... then parts of the stator / coils are going to get rubbed on and messed up also. be safe with the flywheel off you can do the same test via the crank taper This one is cold motor and without the panel |
![]() UTC
I uploaded two more video this morning with the sito plus after a 9 mile drive. To me the sound is gone. I did shake and banged the hell out of the sip sport but nothing felt loose or rattled. This is until I can get the flywheel pulled this weekend. Have a great day
all vespas make noise like that...
but you might want to start thinking about a rebuild to make sure you don't grenade the engine this next year. they need a checkover / rebuild every few years when used every day if the flywheel has as much movement as I saw in a previous post the you getting close to a failure. All mine don't have any play in them in any direction. don't want that to happen on the way to a rally in the summer months either get it done during this winter or risk the 2014 summer riding season a back up complete engine might be good to have in the garage be safe |
![]() UTC
spiderwebb wrote: all vespas make noise like that... but you might want to start thinking about a rebuild to make sure you don't grenade the engine this next year. they need a checkover / rebuild every few years when used every day if the flywheel has as much movement as I saw in a previous post the you getting close to a failure. All mine don't have any play in them in any direction. don't want that to happen on the way to a rally in the summer months either get it done during this winter or risk the 2014 summer riding season a back up complete engine might be good to have in the garage be safe |
Dude we will check all the above this weekend. Great ideas and all of them are pretty easy to do. I have a fly puller and I'm pretty sure I have a crank woodruff key. If needed we can pull the clutch and take a peek at the cush but I don't think that that is it. I rode the entire CBR with a popped cush rivet.
It could be something as simple as the flywheel hitting the cover or cowl. If it's time for a rebuild we can do it over at my place. We did Mel's Rally there and it finished the Corsa! |
ScooterRaton wrote: Dude we will check all the above this weekend. Great ideas and all of them are pretty easy to do. I have a fly puller and I'm pretty sure I have a crank woodruff key. If needed we can pull the clutch and take a peek at the cush but I don't think that that is it. I rode the entire CBR with a popped cush rivet. It could be something as simple as the flywheel hitting the cover or cowl. If it's time for a rebuild we can do it over at my place. We did Mel's Rally there and it finished the Corsa! take pictures and notes along the way renew worn parts like clutch parts, springs and cush drive parts, brass bushings ...ect... replace all bearings and seals upgrades are nice too - porting / port timing checks - flow and match the cases while every things is apart - open up intake and exhaust - cut the crank to increase intake timing and open up the rotary sealing surface a few mm's - chamfering along the way - have hot rod Al lighten up that stock flywheel to around 1800g...!! Stock is around 4000g's all this shall give you a few hp, allow engine to run smoother and cooler while making better power. Might as well throw on one of these too: http://jet200.com/catalog/product_info.php?products_id=2256 don't forget to up the jetting a little too after these mods have fun
Positive
Yeah we'll go over it first. IF it needs a rebuild it's up to Rroddger how he wants to go. All those things are fun to do but the coin starts adding up fast!
![]() UTC
update
On Saturday ScooteRaton, Melanie, Juan (Vespisti1) and George (all vintage peeps) got together to help me. Juan checked the motor and found no fault with it. So now you can not hear the pinging hot or cold.
I did have a wobble in the front when applying the front brake or going over slight cracks. So the shock was the problem to that. George had an extra shock from a Stella and we proceeded to mount it. The nut on the top fender were kinda stuck we had to take the wheel off to get that 33 year old shocks off. After some extensive testing the wobble was gone but there still a shake from the drum being oval, which was there when I bought it(need to buy new drum). We did swing by the Ft Lauderdale Vespa Dealer and got to see and sit on the new 946 vespa.It is a very nice vespa... but that seat is hard has hell. I want to thank everybody for the insightful help and answers to this. My scooter gang that came out to help and I love them for that. They are the best kinda people to me. Have a good holiday to all ![]() |
Vintage folk are some of the most generous folks I've run across. I'm glad that it's sorted and you're back on the road.
Killo wrote: Vintage folk are some of the most generous folks I've run across. I'm glad that it's sorted and you're back on the road. For me the people are pretty much as much fun as the scooters! |
Killo wrote: Old people are some of the most generous folks I've run across. I'm glad that it's sorted and you're back on the road. |
Cylinder head leak!
roggerdavid wrote: I uploaded two more video this morning with the sito plus after a 9 mile drive. To me the sound is gone. I did shake and banged the hell out of the sip sport but nothing felt loose or rattled. This is until I can get the flywheel pulled this weekend. Have a great day |
![]() UTC
Nyle wrote: Cylinder head leak! roggerdavid wrote: I uploaded two more video this morning with the sito plus after a 9 mile drive. To me the sound is gone. I did shake and banged the hell out of the sip sport but nothing felt loose or rattled. This is until I can get the flywheel pulled this weekend. Have a great day |
roggerdavid wrote: if it is an cylinder head leak would it leak liquid from it? How do I go by finding this? find drip check nuts for spec with a torque wrench if the leak returns / doesn't go away after you cleaned off the oil and dirt then you shall have to pop off the head and do a little work - lap head to make sure it is perfectly flat - new head seal if needed - install head correctly so it does not get warped again |
![]() UTC
![]() UTC
roggerdavid wrote: will check this tomorrow... thanks again Spiderwebb.. Thanks to everybody who help me. |
