1967 VLB VESPA 150 SPRINT 1980 P150X 1973 SPRINT VELOCE
Hey all,
im nearing the final step to complete my sprint restoration for my wife.
Im stuck on what to do wrt the wiring.
Had a look at the PX engine and it has 3 wires coming out of the engine from the px stator plate
I have a brand new Sprint Loom which has 5 wires iirc that connects in the junction box to what would have been 5 wires that come out of a sprint engine
items that i have to support this conversion
PX engine with stator plate, flywheel and electronic unit
Voltage regulator part no 16163900
Brake light switch "shutter" e.g. part no 18163700
All bulbs in 12V
what i dont have is the
Conversion wiring loom SERIES PRO, e.g. part no 8613400 from SIP.
I have the funds to order a Loom, but i unfortunately dont have the time to order it and have it couriered to South Africa, especially over festive when things generally "grow Feet" and never arrive
please electic wizz's please advise... i have 7 days to the unvailing for my wifes birthday on the 24th.. once the electrical is sorted i just need to run the cables then im done.
So basically what i need is, someone who can explain to me how to build my own conversion loom and how to connect it up.
⚠️ Last edited by 2Hip2Trip on UTC; edited 1 time
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
Something isn't right. Take a picture of what you have. Show the wires from the stator.
Also: Please proofread what you posted. It is difficult to help when you give conflicting info. Sprint Loom coming from the stator? 12v break[sic] switch?
thanks for the Reply, i cant believe i typed out that post lol... i corrected it to make it much more easier to understand what i'm asking.
@joshzingzing avatar
but still you say 3 wires offv a px stator
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
At the minimum you'd have 5 wires off a stator, at the most you'd have 7 for a starter model (battery).
You are over looking something.
Re: Retrofitting P150 x into Sprint Body **electrical Questi
3 wires? I take it that, it's a 12v points type stator?
correct
@rob_hodge avatar
@rob_hodge avatar
The quick and dirty way to do it would be to:
run a wire from the engine's blue wire to the voltage regulator.
Then, run a wire from there to the taillight.
Run a wire from the regulator to the. Brake switch
Then from the brake switch to the brake light.
Run a wire from the red wire to the ignition coil
Run a wire from the red wire to the kill button
Run a wire from the black wire on the engine to the voltage regulator.
Run a wire from the black wire to the inside of the handlebars.(ground)
Ru n a wire from the voltage regulator to the. Headlight, or headlifht switch if you have a switch with the kill button on the front.
That will at least get it rideable.
thank you Rob. Appreciate your assistance
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
2Hip2Trip wrote:
correct
Points?! Doh!!
[ Time: 0.0116s ][ Queries: 3 (0.0018s) ][ live ][ 335 ][ ThingOne ]
