@bazzer avatar
Vespa Sprint
@bazzer avatar
Vespa Sprint
Hi Guys,
I've read a bit, not much though, and watched a few videos on youtube about using Molasses, anybody else got some advice on how to clean up an old fuel tank without damaging it.
@joshzingzing avatar
lots of nuts and bolts and shaking
molasses sounds like a really bad idea to me, sugar plus heat n end up with a toffee cylinder etc
nothing at all
nothing at all
If its just crappy ole fuel and sludge than simple green and good strong spray nozzle.
If its got some rust then throw some gravel or nuts and bolts or a 1'4 pound of some roofing nails in there with some simple green and shake that fucker around for a while.
If its bad do the same thing twice.
@1978p200 avatar
p200
@1978p200 avatar
p200
Drain cleaner will work. ONE 1/2 once PER TANK FILL WITH WATER KEEP COOL...I just don't know what you have down there to use.. I use toilet bowl cleaner or drain cleaner "acid" in my tanks.. works great..
Just let it set for two days then.. Drain 75% out and use the nut and bolt method.. "OPEN SLOWLY TO LET THE PRESSURE OUT" then flush with water... cut some two stroke oil down with gas and add right after the flush to stop flash rusting..and then your good..
56/57/58? wide frame Allstate
For just plain rust I've had good results from molasses- the chemistry is some kind of chelation. I've used a 10% molasses and water solution, and left the parts in for a month. Here's how a 120 year bicycle chain turned out:
http://s53.photobucket.com/user/gormanao/media/Cushion%20Tire%20Safety/molasseschain.jpg.html
There are a lot of witch doctor derusting schemes. This worked for me.
@bigben avatar
Evil
p2, jet2, lml166
Evil
@bigben avatar
p2, jet2, lml166
yup, nuts and mineral spirits is my trick.
Rally180
Rally180
There is a toilet bowl cleaner called "Works" for sale for $2 at Ace hardware that you just pour in and fill the tank with water. After 10-15 minutes pour it out and the tank is bright and shiney inside. Quickly coat the inside of the tank with a gas/oil combination and away you go....
looks like it works well !!, i only put it on yoghurt or porridge cheers
still i have memories of the old trick. cup of sugar in the fuel tank of someone you hate
@alanmac avatar
'74 Rally, '72 Sprint
@alanmac avatar
Better you than me. My nuts ain't going near any mineral spirit.
@trumpyscooter avatar
Black 2007 PX200, Dark green 1986 PX225 Pinasco, "1972"(yeah rite) Tangerine px200, several TRIUMPH TIGRESS SCOOTERS
how much rust is inside? are we talking scale flakes or just surface?
If its just surface, then a shake with nuts, bolts, nails and 100+mls of crc for 10 minutes may do it.
But if its flaking scale, use nuts bolts nails and zinc phosphate acid. Shake for about 10 minutes, let it sit for 20 then flip it and do the other side. Rinse with water, you may need to repeat it a few times. Use a blow dryer to dry it out. Then squirt a heap of crc in there to keep it from corroding.
You can tie it to a clothes line through the bolt holes with the tap and cap plugged up and just spin it round. Works heaps easier than shaking the damn thing.
If you have rust and some scale , put some nuts, bolts, clean small gravel, etc in the tank, tape up the openings, wrap up in an old towel or blanket and run it thru a cycle in the clothes dryer - no heat of course. Just make sure your lovely lady is not home at the time, too many questions - not enough lies. Good Luck
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
A 10:1 water/molasses solution actually will work. It creates an acetic acid that dissolves rust. But it's a slow process. There are at least half a dozen relatively inexpensive products that remove and inhibit rust and do it much faster and more effectively using phosphoric acid solutions.
Ospho, Fast Etch, Krud Kutter's Must for Rust, even good old Naval Jelly will all deoxidize the inside of your tank and coat it in much less than a month.
1961 vbb and 1981 p125x
I've used molasses and it hasn't taken a month. It is pretty slow thou. Toilet cleaner does work well. I shy away from putting nuts and bolts inside as sometimes a rusty tank isnt just rusty but also thin. I have rinsed with diesel fuel but premixed should do the same.
@lango avatar
62 VBB 64 GL Rally 200s 74s-76-77 P200s 79-82
@lango avatar
I used acetone and my tank looks awesome
I just cleaned the tank on the rally - it was parked for 34 years. I was told to use acetone and a chain - and I used gravel instead. Medium sized gravel. I let it soak a while. Be careful the acetone will destroy paint and the knob on the fuel cap if allowed to soak. I wiped off any drips and my paint is fine.
@rob98801 avatar
85 Vespa PX150E with sidecar, 80 P200 with sidecar, 96 Goldwing with Hannigan Sidecar, LR87aj5, LR91aj3
@rob98801 avatar
I bought a paint shaker from Harbor Freight a few years back. I now put it to good use cleaning out tanks. A cup of 1/4 nuts and 30 minutes later the inside of the tank is spotless.
Paint shaker? Just suspend from bungees & use kidpower.
@vader19 avatar
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
@vader19 avatar
V oodoo wrote:
Paint shaker? use kid power
Is that legal?
nothing at all
nothing at all
Vader19 wrote:
Is that legal?
That's exactly what kids were invented for.
^^^ correct
plus they earned 5 euro each for both putting in multihours of shaking.
@blacky avatar
VBB
@blacky avatar
VBB
I use the gravel method , then wrap the tank in a towel and put it in the cement mixer for a couple of hours.
hillbilly gravel ?
@blacky avatar
VBB
@blacky avatar
VBB
joshzingzing wrote:
hillbilly gravel ?
Of course !!!
[ Time: 0.0088s ][ Queries: 3 (0.0026s) ][ live ][ 334 ][ ThingOne ]
