@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
So a while back I managed to drill out the lock on my smallie column. That went well. What I didn't do so well was how I handled the lock cover rivet. Scooterhelp and others tell you that you can vise-grip that sucker out. I was skeptical but tried it and of course it bungled the top up so bad that I ended up drilling it out to get it out of the way.
What that's left me with is an oversize odd-shaped hole. I'm sure I can fix up odd shaped but I doubt I'll find a rivet to work by the time it's round again. I could try to tap a thread in there and use a screw. My other idea is to JB Weld up the hole and drill it out to proper size and use a proper rivet, but I'm not sure if it will be too "crumbly" to hold the rivet when you install it.
At this point I know the proper fix is to weld it and drill it but that's really only appropriate if I'm going to paint the bike, which I'm not.
I'm not opposed to unusual solutions that don't involve the lock cover, but I'd like to get either the cover or a washer over the lock tab so the lock doesn't want to fall out if you turn the key, etc.
Ideas?
@xkrebstarx avatar
1966 Bluebadge, 1974 Super 150
@xkrebstarx avatar
Ouch... Dremel an oversized rivit into the odd shape? Maybe leave it a little too big so that it holds?
Good luck!
@scootermarc69 avatar
I think JB weld will work. Try that first.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Good luck!
I'd drill the hole round first
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Yeah it seems low risk and won't make anything worse even if I have to drill it out.
[ Time: 0.0133s ][ Queries: 3 (0.0059s) ][ live ][ 313 ][ ThingOne ]
