12
Are there non-heated gloves (because my Vespa is not fitted to do the heated gear stuff) that can keep your fingers warm around 0-50 degrees f in about 80mph speed?
![]() UTC
Posts: 7674 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2013 Piaggio BV 350, 2014 Can Am Spyder RT
I have the competition elkskin ropers, and really like them down to ~35F.
Aerostich also has an insulated elkskin roper with gauntlets, which I actually plan on getting in the next few months for colder weather. Very soft and comfortable, given how tough they are. http://www.aerostich.com/clothing/gloves/elkskin-and-deerskin-gloves |
![]() UTC
I was out riding at 20F, and had on ski gloves. It was OK, but after half hour or so started getting cold. I think it would be much better if my windshield was in front of my hand, but it isn't. BTW, I'm from Minnesota, so maybe a bit less prone to being 'chilly'.
In any case, I do plan on getting those Aerostich gloves at some point next year. |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 44785 Location: Pleasant Hill, CA |
noeltazz wrote: Have been looking online, it seems like non-heated gloves are only good to about 35? |
![]() 2006 Vespa GTS250ie, 2005 Vespa ET4, 2022 Royal Enfield Himalayan, 2001 Kawasaki W650, 2023 Honda Trail 125.
Posts: 2482 Location: Central Pennsylvania |
The 80mph wind is a killer for hands that aren't protected. My Gerbing Electric gloves won't keep my hands warm in that. Whatever gloves you get you are going to need some wind protection in my opinion -- muffs most likely. They're not pretty but they work.
My Gerbings are great and aside from long exposure to high speed riding they work well down to zero for me. |
noeltazz wrote: perhaps the termoscud muffs would crush the cold? |
Termoscud - extremely dangerous?
The termoscud muffs (and all muffs) seem extremely dangerous by design to me.
I'm use to moving my hands ALL THE TIME when I ride. For example, if I change lanes, sometimes I'll also stick my hands out to signal as an added extra signal for all drivers to know that I'm about to move. If my hands are in the muffs, and I instinctively do this, without removing my hand first, won't I violently jar the handle bar and send me flying? Another example is my bluetooth helmet, there's a button on my helmet to skip the current track, I'm constantly skipping tracks and moving my hands to do stuff on my helmet. |
I would say it will only be dangerous if you don't change how you operate.
I've only ridden briefly with muffs on a motorcycle and aside from a slight adjustment of motion to get my hands in and out it was no big deal. It became second nature to me pretty fast, sort of like getting my feet in and out of toe clips on a bike. Can't speak to the bluetooth -- I ride for as much silence as I can get and use earplugs as well. |
I far prefer the Bagster BOX-R muffs to the Thermoscud or Tucano Urbano ones. Full use of hands and controls, but the wind (and rain if that's the reason for wearing them) kept off. Plus they are very quick and easy to remove and put on again should one need to, no faffing about.
True, you have to learn to 'insert' your hands into the muffs when you inevitably remove a hand from them for something (a wave perhaps, or to crack open/close a visor) - but it is almost instantly 'second nature', no fumbling at all. |
![]() UTC
Vespa 2012 GTS, 1981 P200, 1981 Ape 601
Posts: 355 Location: Oklahoma City |
![]() Vespa 2012 GTS, 1981 P200, 1981 Ape 601
While not a "riding" glove. I use something like this.
http://www.the-house.com/da6blzm04bk13zz-dakine-snowboard-mitts.html A good snowboard mitten. The one I have actually has a full insulated glove "inside" the outer wind and water proof mitten. I have worn these in the 10's all day outside skiing and boarding, and down into the 20's on the scooter running in the 50-60 mph range. One the scooter, every part of my body was freezing through the layers and leather. But my hands were downright toasty. |
There is a discussion on another forum about some $17.50 gloves. I picked up a pair but haven't had the chance to ride with them yet. http://www.advrider.com/forums/showthread.php?t=940062
Re: Termoscud - extremely dangerous?
noeltazz wrote: The termoscud muffs (and all muffs) seem extremely dangerous by design to me. I'm use to moving my hands ALL THE TIME when I ride. For example, if I change lanes, sometimes I'll also stick my hands out to signal as an added extra signal for all drivers to know that I'm about to move. If my hands are in the muffs, and I instinctively do this, without removing my hand first, won't I violently jar the handle bar and send me flying? Another example is my bluetooth helmet, there's a button on my helmet to skip the current track, I'm constantly skipping tracks and moving my hands to do stuff on my helmet. |
![]() 63 GL 150, 05 Typhoon, 09 Beo 200
Posts: 1725 Location: Grand Pothole Rapids, Michigan |
Those $17.50 gloves are not sold as motorcycle gloves....
Anything Motorcycle or Marine or Aviation on it, tend to have high prices! And they are the manufacture of them, so middle man markups.... Quote: RefrigiWear, Inc., is the industry's leading manufacturer of insulated industrial work wear, accessories, and personal protective equipment for use in subzero temperatures, inclement weather, and low-visibility environments. |
![]() GTS 300ABS, Buddy 125, Buddy Kick 125
Posts: 13524 Location: Oregon City, OR |
noeltazz wrote: The termoscud muffs (and all muffs) seem extremely dangerous by design to me. |
Steve said it and Sully eluded to it. When the temps get in the teens muffs are a must. There is no glove warm enough for me without muffs.
tomjasz wrote: Steve said it and Sully eluded to it. When the temps get in the teens muffs are a must. There is no glove warm enough for me without muffs. Is it simple enough to put them on in the morning, take them off at noon, and then put them back on again at night- on the same day? I assume they fit in the pet carrier? This is LA/SF weather, huge deviations in intra-day temperature. 65 during the day and then 40s at night. |
okcgravity wrote: While not a "riding" glove. I use something like this. http://www.the-house.com/da6blzm04bk13zz-dakine-snowboard-mitts.html A good snowboard mitten. The one I have actually has a full insulated glove "inside" the outer wind and water proof mitten. I have worn these in the 10's all day outside skiing and boarding, and down into the 20's on the scooter running in the 50-60 mph range. One the scooter, every part of my body was freezing through the layers and leather. But my hands were downright toasty. |
I'm confused. You wrote 0-50. Now we're talking 40. My Held insulated goretex gloves do well in the 40's. As an aside, I forget sometimes how sensitive I was to cold living in S Nevada and traveling to California. Actually the coldest I've ever been was in the desert. My muffs would be a pain in the ass to remove and replace. You sound like the perfect candidate for heated grips.
tomjasz wrote: I'm confused. You wrote 0-50. Now we're talking 40. My Held insulated goretex gloves do well in the 40's. As an aside, I forget sometimes how sensitive I was to cold living in S Nevada and traveling to California. Actually the coldest I've ever been was in the desert. My muffs would be a pain in the ass to remove and replace. You sound like the perfect candidate for heated grips. Do heated grips really work? Won't the top of your hands still freeze? the heated element only touches your palms no? |
noeltazz wrote: Do heated grips really work? Won't the top of your hands still freeze? the heated element only touches your palms no? |
![]() LX190 Friday afternoon special, [s]Primavera[/s], S50, too many pushbikes
Posts: 10937 Location: Hermit Kingdom |
noeltazz wrote: This is LA/SF weather, huge deviations in intra-day temperature. 65 during the day and then 40s at night. tomjasz wrote: I'm confused. You wrote 0-50. Now we're talking 40. |
noeltazz wrote: tomjasz wrote: Steve said it and Sully eluded to it. When the temps get in the teens muffs are a must. There is no glove warm enough for me without muffs. Is it simple enough to put them on in the morning, take them off at noon, and then put them back on again at night- on the same day? I assume they fit in the pet carrier? This is LA/SF weather, huge deviations in intra-day temperature. 65 during the day and then 40s at night. In CA, if the temps are going anywhere near freezing during the week, the muffs are on. If it's definitely going to stay above 45F for a week they'll come off again. In the UK, where rain can happen at any time often without warning, I tend to leave the muffs on all year round regardless of the temps, unless we're guaranteed a dry spell. They keep the sun off the hands as well. |
I just fitted a pair of the Tucano Urbano muffs (R361) to my GTS - easy on, easy off. I rode to pick up dinner (take-out) the other night in low-40s with my summer gloves on inside the muffs, and I was very comfortable.
Masala wrote: I just fitted a pair of the Tucano Urbano muffs (R361) to my GTS - easy on, easy off. I rode to pick up dinner (take-out) the other night in low-40s with my summer gloves on inside the muffs, and I was very comfortable. ![]() |
Al Davis wrote: Masala wrote: I just fitted a pair of the Tucano Urbano muffs (R361) to my GTS - easy on, easy off. I rode to pick up dinner (take-out) the other night in low-40s with my summer gloves on inside the muffs, and I was very comfortable. ![]() |
Masala wrote: Al Davis wrote: Masala wrote: I just fitted a pair of the Tucano Urbano muffs (R361) to my GTS - easy on, easy off. I rode to pick up dinner (take-out) the other night in low-40s with my summer gloves on inside the muffs, and I was very comfortable. ![]() |
noeltazz wrote: Have been looking online, it seems like non-heated gloves are only good to about 35? http://www.aerostich.com/aerostich-electric-warmbib.html |
dane nordkap xtreme gore-tex are great, it's a 3 finger glove. I used them riding at -3°C and my fingers weren't cold after 40 minutes.
http://www.motoport.nl/Dane-Nordkap-Xtreme-Gore-tex/nl |
![]() 2009 GTS 250ie "Jigokuchou" 2001 ET2 "Luna"
Posts: 1574 Location: Minneapolis MN |
My sister in Denver just got the women's version of these and swears by them.
http://www.compacc.com/p/Joe-Rocket-Sub-Zero-Gloves |
These may not be attractive, but they keep you hands warm and dry when worn over leather riding gloves.
http://www.aerostich.com/rain-glove-covers.html My husband uses these and I use Playtex rubber gloves. They will keep your hands 100% dry and quite warm when worn over leather riding gloves. No wind can get through. If it is really cold, 30-40 degrees in Florida, I use a silk glove liner, thin leather gloves and these. You might find a silk glove liner, from a ski wear store or Lands End, is all you need. |
So I picked up a Dainese Stelvio yesterday and did a test ride tonight in a temperature range of about 46 - 55 degrees fahrenheit and my hands were incredibly cold.
Guess will have to try the muffs. |
RIP
![]() 2006 PX 150 & Malossi Kitted Malaguti Yesterday (Wife's)
Posts: 12955 Location: Paros Island, Greece |
GoreTex will keep rain out, and still allow moisture from your body to escape. It is not an efficient insulator, and it does not stop wind. To prevent cold wind from entering Gore-Tex gloves, you would need an complete outer layer of impervious material, which would defeat the "breathable" feature of the Gore-Tex. Thus, most Gore-Tex gloves have venting areas.
Try on some nice, heavy duty, insulated leather ski gloves for really low temps, and nylon shell ones for moderately cold temps. That's what I wore in WA State when the temps got low. They may not be armored in the manner of riding gloves, but the ones I had would indeed have provided sufficient abrasion protection in a spill. And they are a hell of a lot less expensive than "motorcycle gloves". Yes, they are generally bulky, but you might just have to choose between warm hands with set music tracks and cold hands that can fiddle with the music player controls on your helmet. Life often means choices. |
Piaggio BV250
Posts: 2429 Location: Historic Route 66 in Oklahoma |
Piaggio BV250
According to the W.L. Gore website (granted, this may be like asking a barber whether one needs a haircut), Gore-Tex materials are considered windproof, having an air permeability of <1.0 cfm.
They have always worked well for me at blocking light Oklahoma breezes. However, in the interest of fair testing I believe I should compare performance while being worn in Greece, maybe Romania.... |
RIP
lawdog
Gore also has "Windstopper" fabric, which would suggest that Gore-Tex is not the ultimate answer for higher wind conditions. It really doesn't take much continuous cold air permeation to cool the human body. Even an effective "low" permeation that reduces the ambient wind from 60 mph to 20 mph has a significant effect. Using a web wind chill calculator, that residual 20 mph would result in a 30.5 degree wind chill when ambient is 40. |
Piaggio BV250
Piaggio BV250
Windstopper, while like Gore-Tex, is stated to be windproof, is not considered to be waterproof. According to the link, Gore-Tex has smaller pores which make it waterproof and windproof, but not as breathable.
I'll bet I didn't need that haircut, either! |
For the last several years, I've worn Carhartt "insulated leather driver" gloves, $32. They're insulated with Thinsulate. They're comfortable into the low 40s for me on the scoot--much colder than that for other uses. I have very sensitive hands due to frostbite some 50 years ago, so I wear the same gloves in all weather, though they're a bit warm in the summer.
They're reasonably waterproof, although I suppose if you ran constantly in the rain for any distance, it would seep through the stitching, but I've ridden as much as 25 miles in the rain without getting my hands wet. My windshield (mid-height Faco) partially shields the handlegrips, so that helps. Cary |
Cary Alburn wrote: For the last several years, I've worn Carhartt "insulated leather driver" gloves, $32. They're insulated with Thinsulate. They're comfortable into the low 40s for me on the scoot--much colder than that for other uses. I have very sensitive hands due to frostbite some 50 years ago, so I wear the same gloves in all weather, though they're a bit warm in the summer. st They're reasonably waterproof, although I suppose if you ran constantly in the rain for any distance, it would seep through the stitching, but I've ridden as much as 25 miles in the rain without getting my hands wet. My windshield (mid-height Faco) partially shields the handlegrips, so that helps. eded? Cary |
